rockhound72
Joined: 29 Oct 2012 Posts: 107 Location: Jacksonville, Arkansas
Posted: Mon Nov 12, 2012 9:09 am Post subject: getting wet |
| My '79 924 just started leaking from somewhere on the driver side. Where is this coming from? |
Posted: Mon Nov 12, 2012 10:43 am Post subject: |
Clouds? _________________ Toofah King Bad
staticsan
Posted: Mon Nov 12, 2012 11:08 am Post subject: |
I'd suspect the windscreen seal. Have you stuck your head under the console to see if you can find where it's leaking?
Wade. _________________ '82 British NA - Which I think I've been very lucky with! |
Harm
Posted: Tue Nov 13, 2012 3:26 am Post subject: Re: getting wet |
| rockhound72 wrote: | | …Where is this coming from? |
Maybe this?
Underneath your windshield wiper motor sits a drain that will delete excess water. Overtime this pipe that
connects to the firewall might get blocked by debris and leafs and such, and will rust from the inside out.
Outside bing inside your Toofah… and you'll end up having wet feet.
HTH
Regards, Harm.
Edit01
 _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
rockhound72
Posted: Tue Nov 13, 2012 8:27 am Post subject: |
Well, both areas seem like likely suspects. I figure I will just seal them both. Thinking about the flex seal spray stuff. As far as sealing the clouds......I'm just s.o.l. on that one Thanks for the help. |
