Martin_924er
Joined: 24 Nov 2010 Posts: 6 Location: Derbyshire, UK
Posted: Sat Jul 14, 2012 11:20 pm Post subject: 924 n/a megasquirt project |
hi folks,
later this year I'm going to convert my 924 to electronic injection and ignition via megasquirt, i know its a big project, but I'm up for the challenge,
I've started to get all the equipment to do it, so heres a list of what I've got so far, please let me know if you think i need anything else.
megasquirt 2
megasim
relay board
lots of wire
IAT sensor
CLT sensor
TPS
wide band oxy sensor and controller
fuel rail
fuel line
fuel pressure regulator
injectors
injector bungs
EDIS4 module
EDIS4 coil
trigger wheel (made by a well known aero-engineering firm )
VR sensor
I've got a few questions which need answering...
for the fuel rail, what distance are between the injectors?
where is the best place for the MAP sensor pick up from the megasquirt?
cheers, Martin _________________ Black 1985 924 lux |
Posted: Sat Jul 14, 2012 11:24 pm Post subject: |
Did you order the MSII with the intention of using EDIS? I heard that you have to tell them that, then they modify the board. Not a plug and play. So I've heard. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
mikebola
Joined: 07 Sep 2009 Posts: 361 Location: Parkside, PA
Posted: Sun Jul 15, 2012 12:08 am Post subject: |
from what I gathered, a new kit should handle EDIS out of the box. at least that's what the site says. _________________ proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs... |
Posted: Sun Jul 15, 2012 12:39 am Post subject: |
injector spacing for the fuel rail is 95mm center-to-center. _________________ erstwhile owner of just about every 924 variant ever made |
Horizonblue
Joined: 13 Oct 2011 Posts: 307 Location: Sorring city, Denmark, Europe
Posted: Sun Jul 15, 2012 6:01 pm Post subject: |
What is the number on the injectors, from which car do they come? _________________ Euro 924, 1976
/P.G. Andersen |
Martin_924er
Posted: Tue Jul 17, 2012 3:36 am Post subject: |
| Horizonblue wrote: | | What is the number on the injectors, from which car do they come? |
They are from...
VOLVO 850 2.0/2.5 1991/06 - 1996/12
205cc @ 3 bar fuel pressure
These are high impedance injectors
Bosch Part Number 0 280 150 779
Volvo Part Number 3507422 _________________ Black 1985 924 lux |
