Chapel Guest
Posted: Sun Aug 04, 2002 3:12 am Post subject: |
anyone ever seen it done?
my friend has a lead on a dirt cheap 924 body and a garage full of Rotary Turbos.
he hasnt had a chance to see the engine bay, and neither have I, but I was told that there is a lower subframe that may cause us some grief...
abduln Guest
Posted: Mon Aug 05, 2002 7:34 pm Post subject: |
I have not seen it done, but it should not be too hard given that the 924 engine bay is relatively clean. If you can get your hands on a MIG welder, a chop saw, and some scrap steel you should be able to build an appropriate crossmember in an afternoon.
Is your friends 924 an older or newer one? Keep in mind that the 924s (modern) is significantly heavier than the old 924; heavy enough to suck some life out of rotary, which doesn't have much lowend torque.
Good luck.
Abdul |
Chapel Guest
Posted: Tue Aug 06, 2002 12:15 am Post subject: |
| I know its a pre 83. |
Joined: 29 Jul 2001 Posts: 2743 Location: Sydney, Australia
Posted: Tue Aug 06, 2002 9:11 am Post subject: |
the earlier the better as far as weight is concerned. The series 1 RX7 was rated at 1050kg down here.
Porsche give the weight of the non-US '78 model year 924 at 1080kg and the '79 - '85 at 1130kg (1185kg for the US version). |
Chapel Guest
Posted: Tue Aug 06, 2002 10:36 pm Post subject: |
| well, I fit into 924s better than SA22C RX7s |
