staticsan
Joined: 19 Jan 2009 Posts: 450 Location: Sydney, Australia
Posted: Thu Apr 12, 2012 10:37 pm Post subject: My idle-speed keeps dropping. |
It's happened twice now.
I've gone for a drive and after a while (after it's hot) I notice that when the 924 idles, the idle speed is something like 500rpm. So when I get home, I find a screwdriver and raise it by turning the screw on the side of the throttle body.
Next time I go for a drive, the same thing. Again, I adjust the idle screw when I get home, taking it back up to 950. This time I put a dot of paint on the screw head to see if it moves. But why should it move?
I did notice that there is a bit of vacuum around the idle screw. Isn't there supposed to be a rubber cap, like over the mixture screw? Could that vacuum be pulling the screw in and lowering the idle?
Wade. |
CorsePerVita
Posted: Fri Apr 13, 2012 12:51 am Post subject: |
I just took mine out and looked at it. Looks like it has a rubber O-Ring below the head on it that helps keep it in place (at least on mine). If that were to crack or shrink or go hard it could get loose and start to back off or move or vibrate. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
tyfighter123
Posted: Fri Apr 13, 2012 2:40 am Post subject: |
Vibration gets it. When I was breaking in my engine my screw keep vibrating in making the idle much higher. _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car) |
staticsan
Posted: Sat Apr 14, 2012 5:22 pm Post subject: Fixed! |
The rubber o-ring just behind the head was old and hard. Replaced that and it keeps its idle speed now. So simple.
Wade. |
CorsePerVita
Posted: Sun Apr 15, 2012 1:06 am Post subject: |
Rock on! _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
