Not another timing problem!
joejax
PostPosted: Mon Feb 20, 2012 7:34 am    Post subject: Not another timing problem! Reply with quote
Yes, unfortunately. I promise, I've been searching and searching, and I'm still confused. On my '81 NA, I am having trouble with the timing marks on the fly wheel.
The marks on my fly wheel are a 0, - (minus) sign and a + (plus) sign, no numbers of any kind. Tag on fender says 0 degrees +/- 1. Not having any luck running good set at that.
I've disconnected the black box and have been adjusting air/fuel mix and idle with my best luck at running OK set near or right on the plus sign.
Seems to run OK like this, just want to be sure if it should be at the + or nearer to the 0, and then I can adjust everything else to try to get this thing running a good as possible.
I got nothin'
Uhhh...you got any pics?
Ian89C4
PostPosted: Mon Feb 20, 2012 8:33 pm    Post subject: Reply with quote
I set mine at 0 and she seems to work just fine (I still have some fuel air issues though)
I am sure you do, but do you have the Cam timing properly lined up?
Perhaps play with ignition timing.
Good luck!
Ian
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
joejax
PostPosted: Mon Feb 20, 2012 10:16 pm    Post subject: Reply with quote
Thanks, Ian. Yes, it's all lined up at TDC, engine off, zero on FW, dot on sprocket. Start engine, using timing light with car running, turning distributor, watching mark on flywheel.
In the window on top of flywheel area, using the notch as reference, runs OK right on the + sign. The closer I get to the 0 the worse it gets, even adjusting mix and idle.
I got nothin'
joejax
PostPosted: Wed Feb 22, 2012 10:55 am    Post subject: Reply with quote
Further research has me thinking the + should have a 10 next to it.
I got nothin'
joejax
PostPosted: Thu Feb 23, 2012 7:52 am    Post subject: Reply with quote
I got nothin'
joejax
PostPosted: Thu Feb 23, 2012 7:56 am    Post subject: Reply with quote
I got nothin'
PostPosted: Thu Feb 23, 2012 8:18 am    Post subject: Reply with quote
Breasts. Not chicken.
joejax
PostPosted: Thu Feb 23, 2012 8:22 am    Post subject: Reply with quote
Hop thise werks!
I got nothin'
PostPosted: Thu Feb 23, 2012 8:38 am    Post subject: Reply with quote
joejax wrote:
Apostrophe fail.
joejax
PostPosted: Thu Feb 23, 2012 8:56 am    Post subject: Reply with quote
Oh, I get it. Kn'uck kn'uck nuck.
(Edit: Not of my creation, far too advanced. My punctuation is usually far more...uh...more good)
I got nothin'
the_mad_electrician
PostPosted: Thu Feb 23, 2012 9:32 am    Post subject: Reply with quote
I think they used the wrong form of your on purpose. That's the joke.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
joejax
PostPosted: Thu Feb 23, 2012 9:50 am    Post subject: Reply with quote
Oh, now I really do get it. Nice one, mad.
I got nothin'
joejax
PostPosted: Fri Feb 24, 2012 11:13 am    Post subject: Reply with quote
I got nothin'
