old 924
Joined: 06 Mar 2012 Posts: 184 Location: clinton twp MI. USA
Posted: Mon Apr 09, 2012 12:52 pm Post subject: head lights dont work right.. |
ok when i got the car the headlight's didnt work at all..i put in the spear switch that came with the car and the light's came on but didnt go up..ive put in a spear relay and greased the rod's and linkage ...after i use the knob to rase them up they will go down the way they should..after playing with them more today ive got them to go up as well but only after i turn the knob a few time's then the motor kick's in..is it still binding up or is the motor just shot..??  _________________ base 77 924 2.0 (may the porsche be with you) |
staticsan
Posted: Tue Apr 10, 2012 10:39 am Post subject: |
Sounds like the contacts in the positioner need cleaning. This is the wheel on the end of the gearbox of the raising motor that tells it when and how far to raise or lower it. It's not hard to take it off, pull it apart and clean it. The trickiest bit is removing the rubber boot.
Also check all the pins in the socket plugged into it are seated. Apparantly they can come loose and lose contact. That is also a source of wierdness.
Wade. |
Posted: Tue Apr 10, 2012 2:56 pm Post subject: |
Sounds like the relay to me, or at least the connections in the relay socket. _________________ 78 924 NA
5-lug |
old 924
Posted: Wed Apr 11, 2012 7:41 am Post subject: |
thank's guy's i'll play with it some more..and like the rest of the older one's i've seen on here my fusebox is a mess also..  _________________ base 77 924 2.0 (may the porsche be with you) |
old 924
Posted: Tue Apr 17, 2012 4:54 am Post subject: |
i cleaned the relay like u guys said but also put on a spear motor that came with the car...work's like new..(about the only thing on the car that dose now) _________________ base 77 924 2.0 (may the porsche be with you) |
Posted: Tue Apr 17, 2012 7:32 am Post subject: |
You will probably find the cams in the motor have dirty contacts.
easy job to remove and clean.
Mine used you go up ok but when switched off they would continously go up and down. _________________ Porsche 924 1984 (UK import) NA
old 924
Posted: Tue Apr 17, 2012 7:42 am Post subject: |
this car has been a pain in the a** from day one..i got the headlight's working the way they should...ive been working on my no start prob..replaced the fuel pump relay car start's..then came the big spark from the fuesbox and wasted the new relay..(but the lights still work fine lol).  _________________ base 77 924 2.0 (may the porsche be with you) |
joejax
Posted: Tue Apr 17, 2012 9:16 am Post subject: |
You should probably think about ripping all those headlight parts out and stuffing some square ones in there...  _________________ I got nothin'
Uhhh...you got any pics? |
