injector plastic pipes& contol pipes
doug60
PostPosted: Fri Feb 03, 2012 7:08 am    Post subject: injector plastic pipes& contol pipes Reply with quote
Hi,
Does anybody know if you can disconnect the flexible plastic pipes from the metal tubing that are used from the fuel distributor to the injectors, or are they machine fitted want to fit a pressure gauge in between.
Thanks
PostPosted: Fri Feb 03, 2012 1:43 pm    Post subject: Reply with quote
If you're referring to the Nitrile lines that connect to the barb fittings, I would strongly recommend against tampering with the stock fuel lines. Besides, that's not where you should be installing a pressure gauge anyway.
What purpose do you have in mind for installing a pressure gauge??? How familiar are you with CIS? You do understand that the fuel is under very high pressure, right? You can't just stick any old fuel pressure gauge in there...
Recommended reading:
http://924board.org/viewtopic.php?t=35734
bruce76-924
PostPosted: Fri Feb 03, 2012 7:04 pm    Post subject: Reply with quote
No you can't split the lines, unless you are having new lines custom made. As Dan says, you don't measure pressure there anyway. Once you establish the control pressures from cold to hot and you have the correct system pressure, then the only thing you measure after the fuel distributor is the fuel volume through the injectors.
Fitting a pressure gauge in the injector line would accomplish nothing except introduce another potential area for fuel leaks. If you use the correct gauge kit ( like Dan sells) and follow the correct test procedure then CIS is very easy to trouble shoot, it is just massively different to any electronic fuel injection.
Bruce.
1976 924 LHD, full cage, semi tube chassis, 951 brakes, lightweight 951 body panels.
1.8t engine conversion with Holset turbo and 6 speed Audi gearbox.
doug60
PostPosted: Sat Feb 04, 2012 3:50 am    Post subject: Reply Reply with quote
[quote="ideola"]If you're referring to the Nitrile lines that connect to the barb fittings, I would strongly recommend against tampering with the stock fuel lines. Besides, that's not where you should be installing a pressure gauge anyway.
http://924board.org/viewtopic.php?t=35734[/quote]
Thanks a lot for the info and the link, a great bit of test gear Just a thought if possible to put the gauge in line from the solenoid to the WUR
Thanks anyway
doug60
PostPosted: Sat Feb 04, 2012 3:51 am    Post subject: Reply with quote
[quote="bruce76-924"]No you can't split the lines, unless you are having new lines custom made. As Dan says, you don't measure pressure there anyway. Once you establish the control pressures from cold to hot and you have the correct system pressure, then the only thing you measure after the fuel distributor is the fuel volume through the injectors.
Bruce.[/quote]
Thanks a lot for the info, got the idea now
