Can you turbo a non-turbo 924?
jseabolt
PostPosted: Sat Jan 28, 2012 8:42 am    Post subject: Can you turbo a non-turbo 924? Reply with quote
Still thinking about this 924 purchase but just out of interest.
I have turbocharged two of my Fiats. One is a 1980 Fiat Spider w/L-jet and the other one is a 1987 Yugo with a Fiat 1500 engine, blown through a Weber 32 DFTA.
Here's the master directory:
http://s222.photobucket.com/albums/dd148/turbofiat/
Both cars have stock engines and drivetrains. The Spider is a 2 liter twin cam with 8:1 C/R running 7 lbs of boost. The Yugo has an 8.5:1 C/R and struggles to make 6 lbs of boost. Probably because the turbo was sourced from a Saab 9000 2.1 liter and is too large for this engine. Also still working on the primary jetting.
Both cars are non-intercooled and both systems were built from scratch by me. Except for the exhaust manifold on my Spider.
I have found these cars to be very reliable at 7 lbs.
The question is what sort of C/R would a 1977 924 have? Would it hold up to a 50% increase in HP (7 lbs of boost) like my Fiats?
If I were to to this all I would really need was the exhaust manfiold and turbo. Any other plumbing would be icing on the cake.
With L-jet the trick is to use a Malpassi rising rate fuel pressure regulator. These work up to about 7 lbs of boost. After that the mixture starts to lean out a bit.
I also placed a pressure switch between the O2 sensor and ECU so it disrupts the signal when the turbo kicks in. Otherwise the O2 sensor picks up on the extra fuel and tries leaning the fuel mixture out. PING!
The ignition trick is to use a GM 5 pin control module from a 78 to 81 Olds or Pontiac to provide 5 degrees retard under boost. These work with any distributor that uses a magnetic trigger. Here is one I retrofitted to a Bosch distributor on my Yugo turbo:
http://s222.photobucket.com/albums/dd148/turbofiat/GM%205%20PIN%20HEI%20module/
Could you use the same trick (boost the fuel pressure up) on a K-jet system as you could on an L-jet system?
PostPosted: Sat Jan 28, 2012 9:22 am    Post subject: Reply with quote
8.5:1 for most of the US I believe. The others are 9:1.
Aside from the headgasket, and some cooling upgrades that might be needed, you should be fine.
http://www.connact.com/~kgross/FAQ/944faq02.html
PostPosted: Sat Jan 28, 2012 10:26 am    Post subject: Reply with quote
Still not 100% convinced it's worth doing but it most definitely can be done. Check out Raceboy's car.
What you can't do is simply pull the turbocharger from 924 Turbo and bolt it onto an non-turbo 924 engine. You may already realise this but I think it's worth pointing out, just in case.
PostPosted: Sat Jan 28, 2012 12:51 pm    Post subject: Reply with quote
^+1
The turbo exhaust mani will not bolt up to the NA head, at least not without modifications to one or the other. Essentially, the entire top end of the 931 is different than the NA. About the only thing in common is the camshaft. Head casting, valves, exhaust mani, dizzy (same body but different ignition curve), intake mani, throttle body, CIS, are ALL different.
I've stated such many times before, and will do so again here. I personally believe the quickest and easiest way to boost the NA is with a belt-driven centrifugal SC mounted in the spot where the 931 alternator is mounted. You'd have to move the CIS in order to make this work, but for this kind of project, that would be the least of the efforts.
Turbocharging is a lot harder to accomplish because of the challenges of adapting the NA exhaust manifold or replacing it. There are some old BAE ex manifolds floating around on cars and abandoned projects, but they're really hard to find.
PostPosted: Sat Jan 28, 2012 12:54 pm    Post subject: Reply with quote
As for US-spec CR, early 77 had 8:1; 77.5-79 had 8.5:1, 80-onward had 9:1. All Euro spec had 9.3:1.
PostPosted: Sat Jan 28, 2012 1:28 pm    Post subject: Reply with quote
Check out the thread by DutchPug on mounting the turbo on the driver's side using the stock exhaust manifold ala Porsche 944 Turbo.
Not saying its ideal, but it's better than the crack prone stock manifold and opens the possibility of turbos other than factory.
Raceboy
PostPosted: Sun Jan 29, 2012 11:03 pm    Post subject: Reply with quote
Actually I think it can be done by just putting on a turbocharger and run it that way. But, as always there are "buts". First thing is the fuel system. CIS can cope with increased fuel delivery needs but it has to be tuned accordingly and one cannot get away without WBo2 meter, either buy it or borrow it. Ignition has to be retarded also a little bit (~5-8 degrees) when dealing with euro spec engine.
And of course, boost pressures should not exceed 0.5-0.6 bars, that would result in around 180-190 hp.
Is it worth it? Hell yeah, especially if 931's are not readily available (which in most parts of the world they isn't) and/or most of them are either trash or expensive.
It would most certainly be worth it if you can hold the welder and wrench.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
jseabolt
PostPosted: Sat Feb 04, 2012 12:30 pm    Post subject: Reply with quote
Thanks for the info guys.
I still do not have this car in my posession. I've been having trouble getting the guy to return my phonecalls. He finally returned my phonecalls today and apologized and said he had been ill so we agreed we would try next week.
Getting back to turbocharging. I did not realize the N/A and turbo engines were different.
Most factory turbocharged engines are built that way. All I've had experience with are turbocharging N/A Fiat engines by building my own parts.
I got lucky and found an aftermarket turbo manifold for my Fiat Spider but had to modify a 4-1 Fiat F.I. manifold for my Yugo. Luckily the casting was good enough to where a SS exhaust flange could be welded to the cast iron manifold using a welding rod high in nickel content.
If I am determined to turbocharge this engine, then looks like I may have to do the same. Hopefully once I buy the car, I'll be able to see how the engine is laid out.
Also like I said I'm not that knowledgable on K-jet. L-jet can easily cope with forced induction with a rising rate fuel pressure regulator. I was hoping I might be able to do the same the K-jet.
PostPosted: Sat Feb 04, 2012 12:46 pm    Post subject: Reply with quote
Word of warning. Throw out everything you know from other cars, as most of it will not be applicable to the 924.
While you're awaiting the outcome of your pending purchase, might I humbly suggest some recommended reading on performance upgrades? This thread will provide you with 80-90% of what you'll need to learn to make an educated decision about whether or not to proceed with an attempt to turbocharge the NA. See particularly the forced induction section. It provides many links to other threads with details on how others have approached this unique problem on the 924 NA platform.
jseabolt
PostPosted: Sat Feb 04, 2012 1:13 pm    Post subject: Reply with quote
OK, I've read some of the links on turbocharging a N/A 924. Maybe I'm just impartial to turbocharging but if there is room for a turbo on the exhaust side, then I don't see why this has to be an expensive upgrade.
Especially if I do the work myself and have most of the parts to build a system from previous turbo systems I've built.
The main thing I was concerned about was the C/R, K-jet tunability and strength of the engine. Some engines are built on the brink of destruction. Honda engines are supposed to be built for fuel economy because the internals are lightweight and do not hold up to performance upgrades. In other words, they will explode if pushed beyond factory specs. So I've read.
Some of the Fiat folks have went with 10:1 pistons, hot cams, etc and complain their engines ping afterwards. So I'd rather not go down that road.
Since I am buying this car for my wife, she may be content with the engine's current HP and not want me to mess with it. So that would be good enough for me. I'll just use my collection of turbo bits on my Fiat 131.
Her previous sportscar was a 2003 Nissan 350Z. Now she drives a Buick because it suits her needs more (grandkids) and misses her sportscar and want's something she can drive occasionaly. Because this 924 she is interested in is >25 years old, I can get an Antique Auto plate and not have to register the car again and collector car insurance so this car would be cheaper to maintain in that aspect.
Actually I was glad to see her Z-car go because it was a headache to work on. So much so I'd take it to a mechanic to have it serviced because I didn't want to mess with it. Each repair bill was at least $400. Used a quart of oil every 2000 miles. And would take me over and hour to change the oil on it.
PostPosted: Thu Feb 09, 2012 5:28 am    Post subject: Reply with quote
jseabolt wrote:
...if there is room for a turbo on the exhaust side, then I don't see why this has to be an expensive upgrade.
Perhaps it's not. It depends on your definition of expensive, I s'pose. Starting from scratch (which I understand you're not), then spending possibly the price of the car again (or more, these things aren't worth much) on turbocharging it could seem expensive. Especially when it could quite possibly devalue the car.
For you, maybe not. In general, I think it's fair to consider it an expensive undertaking.
jseabolt wrote:
The main thing I was concerned about was the C/R...
Should be fine, given previous efforts.
jseabolt wrote:
...K-jet tunability...
All but zero, as I understand it.
jseabolt wrote:
...and strength of the engine.
Built like a tank.
I can't begin to describe how awful an automatic toofah would probably feel to her, compared to one of those.
PostPosted: Thu Feb 09, 2012 7:28 am    Post subject: Reply with quote
jseabolt wrote:
OK, I've read some of the links on turbocharging a N/A 924. Maybe I'm just impartial to turbocharging but if there is room for a turbo on the exhaust side, then I don't see why this has to be an expensive upgrade. Especially if I do the work myself and have most of the parts to build a system from previous turbo systems I've built.
Why expensive?
- Fabricate a new exhaust manifold
- Fabricate new downpipe
- Fabricate new wastegate dump pipe
- Plumb lubrication lines (where exactly are you going to pull oil feed from on an NA???)
- Relocate alternator from exhaust side to intake side
- Move CIS system to accommodate relocated alternator (to where, I don't know...)
- Modify CIS system to adjust fuel pressure for MAP and deliver enough fuel to avoid blowing up the engine
No one is saying it can't be done. But it's like pulling a thread. You don't just bolt a turbocharger onto a 924NA motor and drive away.
You also can't just pick up a few parts from a 931 and bolt them on. You can't bolt a 931 exhaust mani on an NA head, and even if you could, you'd still have to do everything else on the list above, to say nothing of the fact that the head would be designed wrong, the intake runner lengths would be wrong, and the car would probably run like a piece of shit if it didn't blow up from detonation due to the higher compression NA pistons and the lack of tunability of the NA CIS system.
You could pick up parts from a 931 donor. But you would need just about everything under the hood except for the block and the rods. And then you'd have to redo a bunch of wiring, as the engine harnesses are different.
If I had the ability to fabricate exhaust components, there's no way I would even mess around with putting the turbo on the exhaust side. If you can weld, move the turbo to the intake side. The stock NA exhaust system would be way easier to modify for this purpose than trying to create your own ex manifold (which would probably be improperly tuned anyway, leading to a whole raft of other problems). But even then, moving the turbo over to that side, you still have the issue of having to relocate the CIS, and none of the other problems go away. As I said, pulling a thread. (Hey, that rhymes!)
I'm sticking with my original comment. If you're really interested in the quickest, least expensive path to forced-induction, you should look at a belt-driven centrifugal supercharger and mount it in place of the A/C compressor. Your only costs would be the supercharger itself, fabricating some brackets, and putting together the chargeair plumbing.
jseabolt
PostPosted: Thu Feb 09, 2012 10:20 am    Post subject: Reply with quote
We will see. I guess it just depends upon how much work I want to put toward building another turbo system. I can see this being an expensive system if I had to hire out the work but like I said this would be the fourth turbo system I have built.
The K-jet system is my main concern because I know little about how to troubleshoot it much less modify it.
If this engine has a C/R of 8:1 and the engine is built strong then I can easily run 7 lbs of boost.
As far as turbocharging VS supercharging goes. I would not even consider supercharging a four banger. Superchargers are better suited for V8s and engines already making ober 200 BHP because they require power to make power where turbos used wasted power to make power.
I would supercharge my 08 Mustang GT before I would turbocharge it but would turbocharge a four banger before superchrging one.
Supercharged are expensive by the way. The cheapest system I've found for my Mustang GT is over $3000.
PostPosted: Thu Feb 09, 2012 12:13 pm    Post subject: Reply with quote
From what I understand, the K-jet system is similar to a carb in how it meters fuel. More air being pulled past the flapper valve, the more fuel, etc.
You can adjust the base pressure fairly easily to compensate a little bit. Ideally you'd need an adjustable WUR (whether electronic or manual) to fine tune the fuel further.
On one of the factory racing efforts they used a 928 distributor with two fuel lines per injector, if that gives you any ideas.
With a wideband 02 and a set of CIS gauges you can probably get it close enough to survive just fine at 7psi. Add an intercooler (or water/methanol injection) and you could probably get it to 12 or so without to much hassle. I can't say the same about the Automatic, but not many have done much with those other than use them as parts cars.
There is a guy in Australia (RC is his username?) that has a supercharged 924 auto that's he's made some changes to his automatic to improve its capabilities. I think he's posted some of his mods in the How-to section, might be useful to you. The blower install was home made and seems to work well.
PostPosted: Thu Feb 09, 2012 12:35 pm    Post subject: Reply with quote
I'm not doubting your abilities except in the area of creating a manifold. I have yet to see anyone successfully build their own turbo manifold without significant expense, aside from the one or two examples cited where the turbo was moved to the other side, and this (as I point out) has a cascading effect on everything else you will do. I'm not trying to dissuade you from your attempt, just trying to point out the dependencies you are going to have to think about in order to come up with an overall solution. As I'm sure you're aware, it must be addressed as a system, not just slapping a turbo onto an existing motor. And as I've tried to point out, this little 2.0L has more than its share of quirks that you clearly haven't encountered before, so much of what you think you know probably doesn't apply.
Then you should start here by getting a better understanding of how it works. I strongly suggest the Probst book on Bosch K-Jetronic, which you can find used for less than $20.
Please re-read earlier posts. The early 77 cars had 8:1; 78-79 had 8.5:1; 81-onward had 9:1. For comparison, the 79-80 US spec turbos had 7.5:1, the 81-82 US spec had 8.0:1; and the ROWs had 8.5:1. My point is, with limited understanding of CIS, let alone how to successfully modify it, you are already in the dangerzone because of the 8.5:1 CR. You better figure out how to control fueling if your going to try to add boost to that set with a head and piston arrangement that weren't designed for it.
I will heartily disagree on this point, as there are many examples of successfully supercharged 6- and 4-cylinder motors. This thinking is clearly from the old-school heavy iron US car perspective.
You can get properly sized used M45 or M62 Eaton blowers all day long for well under $400, either of which would be an excellent candidate for modestly boosting an NA.
