poorsha924
Joined: 13 Nov 2007 Posts: 143 Location: Kansas City Mo
Posted: Sun Nov 27, 2011 5:18 am Post subject: does anyone know for sure? relkated to post WTB dipstick |
wanting to install late model 924 2.0 dipstick& tube assembly in my 1979 924 can not keep oil frtom leaking with the old style dipstick that goes directly into the oil pan
the $64.00 questoin is will a 944 style 2.5 & a 924 2.0 interchangeable or do I have to go with a late model 924 2.0 dipstick& tube assembly? on the research I have done no one knows for sure anyone been there done that?
thanks
Steve
85MPH speedo's are so wrong _________________ 79 924S snailshell
audi big bore t-body
16" turbo wheels |
Posted: Sun Nov 27, 2011 7:07 am Post subject: |
I had a tube dipstick in my race motor for a while and it will fit. However, in my case it read high - meaning it read as if the engine was at "full" when it wasn't really It was actually low by about 1/2 quart.
I replaced all that with the non-tube style and all is happy now.
YMMV |
Posted: Sun Nov 27, 2011 9:17 am Post subject: |
Have you cleaned your crankcase breather screen recently? _________________ White 87 924S "Ghost"
poorsha924
Posted: Sun Nov 27, 2011 11:17 am Post subject: dipstick |
hi guys
thanks for your input Emoore so you are not have oil leaks with the non tube dipstick?
as far as I know the breather has never been cleaned maybe that could be my problem ? I thought when the breathers clog you will get oil in the air filter housing mine is dry What is the best way to clean the crankcase breather?
Steve _________________ 79 924S snailshell
16" turbo wheels |
Posted: Sun Nov 27, 2011 11:27 am Post subject: |
The hose that puts oil in the air intake near the air clearer is attached to the crankcase breather. _________________ White 87 924S "Ghost"
poorsha924
Posted: Sun Nov 27, 2011 12:02 pm Post subject: crankcase breather |
Hi Paul
The oval shaped housing on the block? So is it removalable to clean If not how would I go about cleaning the breather system Could this be causing the oil leak @ the dipstick?
thanks
Stetve _________________ 79 924S snailshell
16" turbo wheels |
Posted: Sun Nov 27, 2011 1:08 pm Post subject: |
Just pull the hose at the air intake end with the motor running and see if any air is flowing.
When its clogged, pressure builds in the crankcase causing air/oil leaks. _________________ White 87 924S "Ghost"
poorsha924
Posted: Sun Nov 27, 2011 9:42 pm Post subject: dipstick issue |
Hey paul
Sounds easy enough If no air is flowing what the best way to clean out the breather compressed air or run some solvent thru the hose ? I relize when you do that will have to change the oil with opition #2
thanks
for the info& insight on my concern
16" turbo wheels |
Posted: Mon Nov 28, 2011 12:14 am Post subject: |
Here's some info:
http://www.924board.org/viewtopic.php?t=24349&highlight=breather _________________ White 87 924S "Ghost"
