Raceboy
Posted: Wed Nov 23, 2011 11:27 pm Post subject: Kinda OT: CNC-porting heads |
It's not for 924 unfortunately, I did it for my 911 heads. Opening up the ports of 911 T heads (32 I/32 E) to 40 mm intake and 37 mm exhaust.
I have 4 axle Heidenhain CNC milling machine at my disposal but of course not too experienced working on it. Getting better by the day though. Main objective is not get familiar with CNC machine per se but to fabricate and modify parts
Few pics:
Finished both intake and exhaust machining yesterday and need to finish the transitions with a burr. After that I'll drill 2nd plug holes too.
Main benefit using CNC machine is that ports are all equal and of course it takes much less time than machining every ports by hand. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Posted: Thu Nov 24, 2011 3:03 am Post subject: |
Drool! _________________ 78 924 NA
5-lug |
flosho
Posted: Thu Nov 24, 2011 7:39 am Post subject: |
I'm boxing up my spare 931 cylinder head. Have at 'er. _________________ [This Space For Rent] |
Martijnus
Posted: Thu Nov 24, 2011 8:38 am Post subject: |
so the thing I don't understand with CNC is that you already have a (semi)product... machining it with CNC means that you need to make a reference, right?
You can't just throw a head on the machine and let the computer figure out where the original port is.... so how do you do that? _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Min
Posted: Thu Nov 24, 2011 12:32 pm Post subject: |
| Martijnus wrote: | | You can't just throw a head on the machine and let the computer figure out where the original port is.... so how do you do that? |
You tell the machine were it is. Usually using a probe type tool.
Raceboy
Posted: Thu Nov 24, 2011 3:04 pm Post subject: |
I wrote a simple program that makes a circle, specified the pitch, spindle speed and depth and just had it repeat it until it was enough (35 mm depth on intake, 25 mm on exhaust ports).
911 heads are good in this respect as they are straight at the start and even though very narrow at the start, they go bigger pretty quickly and by 35mm, they are almost 40 mm. Kind of wrong shape of taper.
I just used the probe to mark reference point (manifold contact surface) and gave it a go.
When dealing with more complex ports, its best to use 3D measuring machine (my employer has it) and alter the image like you want it to and then use Solidworks or Autocad to get the drawing into proper format. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
