aiming head lights specs
bgammie1
PostPosted: Sat Oct 08, 2011 12:55 pm    Post subject: aiming head lights specs Reply with quote
My headlights need adjustment they are aimed up too high.
Noticed that folks in front of me sometimes get annoyed.
In the old days there were service stations with a wall you could pull up to at a specific distance and the lights were adjusted onto the focus spots on the wall. Does anyone know what these specifications are for the 924?
BFG
1982 Porsche 924 NA
PostPosted: Sat Oct 08, 2011 8:13 pm    Post subject: Reply with quote
This varies from state to state and country.
Local dept of transport may be of help or garages that do inspections.
PostPosted: Mon Oct 10, 2011 11:12 pm    Post subject: Reply with quote
A quickie solution off the top o' my head (for use if you can't find any official specs)..
Aim perpendicular toward a flat wall on a flat surface at night.
Pull forward with lights on, note the bright spots.
Pull straight back and watch for the beam spots to drop and shift toward the right*.
*Obviously this is where a spec would come in handy. You'd want to know how much the beams should drop and shift at a certain distance..
As a general guide in the absence of a spec, do the same with some other cars that apparently don't annoy other drivers to see how much their beams drop+shift.
