front wheel bearings
Clbmkr1
PostPosted: Tue Sep 27, 2011 11:06 am    Post subject: front wheel bearings Reply with quote
Guys,
My Haynes Manual says to tighten the spindle nut while rotating the wheel until its snug, then loosen 1/2 turn.
Is this correct? Why loosen it? It seems too loose to me.
Jim Baldwin
1980 931
2013 Lincoln MKZ
2013 Ford Escape
PostPosted: Tue Sep 27, 2011 12:19 pm    Post subject: Reply with quote
It needs to be slightly loose. You should be able to move the washer with a screw driver when you're done.
PostPosted: Tue Sep 27, 2011 12:43 pm    Post subject: Reply with quote
It will expand as it heats up, too tight and you could cause excess friction and potentially have a failure of the bearing or worse.
PostPosted: Tue Sep 27, 2011 4:05 pm    Post subject: Reply with quote
Some related discussion here.
In my experience, a bearing a bit too loose will fail more quickly than a bearing a bit too tight. You'll find the majority of the advice here will, as above, recommend a fairly loose bearing.
78 924 NA
5-lug
