Install block breather
PostPosted: Thu Jul 21, 2011 12:29 pm    Post subject: Install block breather Reply with quote
What is the best way to do install the block breather???
For reference: 931.107.063.00
When I installed the one on the freshly-built Club Sport motor, I banged it up pretty good trying to use a large socket to smack it in. The fitment is very snug (I know, that's what she said), so I can't think of a better way to install it.
Suggestions???
leadfoot
PostPosted: Thu Jul 21, 2011 6:30 pm    Post subject: Reply with quote
Dan, it's a fairly good interfeance fit, just work around the lip with a large flat blade screwdriver tapping it in, the lip is fairly rigid,
I did this in situ with the old car, and put the edge nearest the engine mount arm in first to get it fairly seated first.
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
stevekat
PostPosted: Thu Jul 21, 2011 7:17 pm    Post subject: Reply with quote
I think I'd put it in the freezer, and maybe even heat the area of the block where it fits, though the freezer would be my first choice. And lube the interface on the block. Not sure how effective it would be with this type of part, put it is worth a try at making the installation a bit easier.
"Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Gone to new home: '81 924T, US version, CGT Intercooler, UTCIS-PT, Euro DITC, Greddy Trust MBC, Forged Fuchs Flat Dish 6's, Factory Recaro's.
PostPosted: Mon Jul 25, 2011 11:44 pm    Post subject: Reply with quote
I ended up putting assembly lube around the rim of it, then used a rubber mallet to get it semi-seated, sort of on one side, then used a large flat blade screw driver placed on the lip and smacked that on the other end with a hammer to get it fully seated all the way around.
PostPosted: Mon Aug 01, 2011 12:54 pm    Post subject: Reply with quote
What & no - pics.
PostPosted: Mon Aug 01, 2011 1:27 pm    Post subject: Reply with quote
Special VW Tool.
PostPosted: Mon Aug 01, 2011 1:28 pm    Post subject: Reply with quote
Rasta Monsta wrote:
Special VW Tool.
Heh! Too funny...Vaughan suggested an appropriately sized piece of PVC pipe
PostPosted: Mon Aug 01, 2011 1:34 pm    Post subject: Reply with quote
Hmm. . .toolbox section of the Garage?
lolo451
PostPosted: Wed Aug 31, 2011 2:52 am    Post subject: Reply with quote
and reverse question: what is the best way to remove it?
i would like to clean it.
924turbo S2 1981
alfa 75 (milano) twin spark 1989
fiat 126bis 1990
leadfoot
PostPosted: Wed Aug 31, 2011 4:48 pm    Post subject: Reply with quote
Flat blade screwdriver,work inbetween the lip and the block and pry it off, careful not to drop anytjing into the hole after you get the beather off,
Stu
