Sway bar bushing
daniel
PostPosted: Thu Sep 01, 2011 6:07 pm    Post subject: Sway bar bushing Reply with quote
Anyone have and want to sell or know of a source for front sway bar bushings for the early type bar. I need the bush that goes on the end of the bar and into the drop link.
I specifically need one made from polyurethane type stuff. Delrin is just too hard and is causing too many drams.
Cheers
Daniel
PS anyone know how to machine the polyurethane bush's? Got a set that have too small an ID
1989 944 Cabriolet
924aussie
PostPosted: Thu Sep 01, 2011 6:29 pm    Post subject: Reply with quote
have you ever tried these guys in Brisbane, we went to the factory many years ago and they make the parts there.
http://www.fulcrumsuspensions.com.au/
Make: PORSCHE
Model: 922 & 924
Series: Early models with pressed steel front wishbones
Production Date:
Available SuperPro PartsFront
Front
Control Arm-Inner Front Bushing
SPF0647K
Requires 1 kit per vehicle Single Kit Contains 2 Inner Tubes, 2 Bushings
Control Arm-Inner Rear Bushing
SPF0648K
Requires 1 kit per vehicle Single Kit Contains 2 Bushings
Sway Bar End Bushing
SPF1169-_ _K
Measure end of bar diameter, 20,21.5,22,23,24,24.5,25.4,26,27 & 30mm ava
Suspension Parts & Poly Bushings for PORSCHE 944 Coupe 1989 - 1991Make: PORSCHE
Model: 944
Series: Coupe
Production Date: 1989 - 1991
Front
Sway Bar To Lower Control Arm Kit
SPF2922-18K
Original Rubber bushing # 951.343.793.30 = Suits factory bar diameter 25.5 & 26.8mm with end size on bar of 18mm
Sway Bar Mount To Chassis Bushing
SPF2923-_ _K
Measure bar diameter, 20,21.5,22,23,24,24.5,25.4,26,27 & 30mm ava, Suits bracket 944 343 731 00
Alan
green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1998 Nissan Silvia ... sons back from OS he has taken it
BIG BLOODY MOTORHOME 300zx Sold
1980 Fire truck Sold
PostPosted: Fri Sep 02, 2011 1:04 am    Post subject: Reply with quote
Hey does he mean OEM type stuff?
daniel
PostPosted: Fri Sep 02, 2011 8:34 am    Post subject: Reply with quote
Thanks Alan
I had a thought last night of using Areldite to glue the bush into the drop link then try to machine it from there. If that dosnt work, ill give thse guys a shot.
Not Joe he dosnt mean OEM type stuff
1989 944 Cabriolet
