Nein37
Joined: 29 Dec 2009 Posts: 513 Location: New London, CT
Posted: Mon Aug 08, 2011 12:17 am Post subject: 30 year old bottom end compression numbers |
Had the IC off the other day and figured while I was in there I'd check my compression.
Cylinder #1 152
Cylinder #2 155
Cylinder #3 154
Cylinder #4 154
Not bad for a 30 year old bottom end that has run 150K miles and undergone some minor abuse.  _________________ 1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears. |
