rebuilt ?????????????????
billygoat
PostPosted: Sun Mar 02, 2014 7:06 am    Post subject: rebuilt ????????????????? Reply with quote
[img]https://imagizer.imageshack.us/v2/4608x3456q50/819/5qza.jpg can u tell by pic if rebuilt took valve cover off to clean car says 85000 looks to clean for the miles is there any marks I should look for thanks [/img]
PostPosted: Sun Mar 02, 2014 8:43 am    Post subject: Reply with quote
I tried correcting the HTML in your post, but the pic is super-sized and not real easy to see anyway...
Here's a separate link:
I'd believe that the head could've been removed and cleaned, but that doesn't imply anything about the block...
Ian89C4
PostPosted: Mon Mar 03, 2014 3:24 am    Post subject: Reply with quote
I see a little bit of oil in the head bolts....have you started the car? The cam lobes look extremely dry. I would toss some assembly lube on them prior to starting.
If you have started and ran it I would pull the oiler tube off and make sure it is not clogged.
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
