loose screws for door fittings
Duncan
PostPosted: Thu Jul 21, 2011 6:56 am    Post subject: loose screws for door fittings Reply with quote
A number of screws in the door, that attach the door pocket, the speaker panel, etc. work themselves loose after a while. What could I do to fix this?
Welding the old holes shut and redrilling them is not an option, as I do not have acces to or skills to handle such equipment.
Any ideas?
Duncan
1983 NA Alpineweiss since 2001
Peugeot 205 Generation
PostPosted: Thu Jul 21, 2011 7:29 am    Post subject: Reply with quote
Here's some options:
1. Slight larger sheet metal screws
2. Speed nuts
3. Nutserts
{EDIT}
Just in case they call them something different in Europe:
Speed Nut:
Nutserts:
Duncan
PostPosted: Thu Jul 21, 2011 7:49 am    Post subject: Reply with quote
Thanks!,
The speednuts will probably do for some. Nutserts must be called differently here, because google does not give any hits in my own language.
Ebay.co.uk shows them!
Duncan
PostPosted: Thu Jul 21, 2011 9:35 am    Post subject: Reply with quote
Nutserts might also be called "rivet nuts".
Duncan
PostPosted: Thu Jul 21, 2011 9:58 am    Post subject: Reply with quote
Yep, rivnuts.
I am studying now which tool is the best for these.
They come as tools that resemble blind rivet tools ($50-$150-brandless and branded), but I also found a tool that is simply a combination of two steel wedges:
http://www.ebay.co.uk/itm/Rivnut-Rivetnut-Nutsert-Fitting-tool-M4-M5-M6-Kit-car-/400228094291?pt=UK_Hand_Tools_Equipment&hash=item5d2f741153
What is the best choice you think?
Duncan
PostPosted: Thu Jul 21, 2011 10:02 am    Post subject: Reply with quote
More options.
http://www.mcmaster.com/#catalog/117/3272/=d9j5iu
