| What do you think? |
| Awesome - great job, great fit-n-finish. |
66% |
[ 2 ] |
| Yuk - don't like it, doesn't belong, another butcher job. |
0% |
[ 0 ] |
| Sweet - when can you do mine (sending you a PM) |
0% |
[ 0 ] |
| Whatever |
33% |
[ 1 ] |
| Total Votes : 3 |
skemcin
Joined: 02 Sep 2003 Posts: 1284 Location: Plainfield, IL
Posted: Fri Jul 01, 2011 1:59 am Post subject: OT: ScanGaugeII Installation (replace center dash clock) |
I did this on my 2002 Subaru Impreza Outback Sport last night. Although our 924s are too old for this (at least most of them) I figured I'd share this for anyone interested. I plan on creating a more formal tutorial but this is what I've got so far.
Your feedback is greatly appreciated.
https://picasaweb.google.com/skemcin/ScanGaugeIIInstall
Tools:
Dremel
Canon EOS Digital Rebel XT
Flathead Screwdriver
Electrical Tape
ScanGaugeII
Time:
2hr 12 min. _________________ 924.org (no time to complete)
9249206346 - 89k – new shifter bushings, belts, running well.
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power |
Posted: Fri Jul 01, 2011 2:11 am Post subject: |
Looks good, man. _________________ Toofah King Bad
thirdgenbird
Joined: 29 Feb 2008 Posts: 367 Location: Pella, IA USA
Posted: Mon Jul 04, 2011 8:03 am Post subject: |
overall i think it looks very good but you have a little room to improve. the transition is not perfect but defiantly workable.
try sanding your edges smoother. you may also be able to carefully paint the "bezel" with plasticoat. it may make it blend better.
I had one of these in my last truck to monitor transmission and head temperature. it now resides in my fusion. i dont need it but i figured i had it
i used a blendmount to mount it in both vehicles. it doesnt look oem but it does look very clean. _________________ 17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel |
skemcin
Posted: Mon Jul 04, 2011 11:21 am Post subject: |
| thirdgenbird wrote: | overall i think it looks very good but you have a little room to improve. the transition is not perfect but defiantly workable.
i used a blendmount to mount it in both vehicles. it doesnt look oem but it does look very clean. |
Thanks for the feedback. I agree, there is definitely room for improvement. This is the first time I've cut up the interior of a newer car so I am very please with the results. Once I construct a better mounting system, I might look at refining the transition points. There is a little bit of a texture to the top surface so I was hesitant to mark it up too much - but the plasticoat suggestion could help there - thanks again. _________________ 924.org (no time to complete)
skemcin
Posted: Wed Jul 13, 2011 4:14 am Post subject: |
Here is the review I wrote on the product - any feedback would be appreciated.
http://reviews.iribbit.net/review/scangaugeII/
Thanks in advance. _________________ 924.org (no time to complete)
