sunroof delete
leadfoot
PostPosted: Thu Jun 23, 2011 11:25 am    Post subject: sunroof delete Reply with quote
anyone changed the sunroof to a solid fixed polycarbonate, I can't see myself ever having this open and apparently need a new seal at any rate.
Are there any universal window seals that could be used ?
cheers
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
v8carreragts
PostPosted: Thu Jun 23, 2011 12:24 pm    Post subject: Reply with quote
This is what I am doing to mine
84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Dodge Charger R/T AWD HEMI
2013 Chevy Cruze
leadfoot
PostPosted: Fri Jun 24, 2011 8:53 am    Post subject: Reply with quote
looks very nice, then welding? or having it removable?
do you think you might please be able to take a close up with the sheet metal out,
cheers
Stu
v8carreragts
PostPosted: Fri Jun 24, 2011 12:21 pm    Post subject: Reply with quote
I am not cutting anything on the roof section. Made the panel by hammer forming it using the old sunroof as a pattern. I am planning on using 3M 08115 Panel Bonding Adhesive to attach it. Then a little polyester filler (Bondo) to smooth the seams. This will make it permanent.
This adhesive is really strong stuff. I used it to bond my rear flares and my hood scoop.
2015 AUDI Q7
2013 Chevy Cruze
PostPosted: Fri Jun 24, 2011 3:03 pm    Post subject: Reply with quote
Nice. I actually grabbed a delete roof skin and will have it welded in and filled. I'll let you know how it turns out.
v8carreragts
PostPosted: Fri Jun 24, 2011 3:21 pm    Post subject: Reply with quote
[/quote] I actually grabbed a delete roof skin and will have it welded in and filled.
Quote:
That's what I wanted to do but I couldn't find one.
2015 AUDI Q7
2013 Chevy Cruze
PostPosted: Fri Jun 24, 2011 4:17 pm    Post subject: Reply with quote
*cough* http://washingtondc.craigslist.org/doc/pts/2456574456.html
Sunroof-less 924s being parted in Washington DC....
AppleBit
PostPosted: Sat Jun 25, 2011 2:11 pm    Post subject: Reply with quote
some photo examples of a deleted sunroof on my car: http://www.924board.org/viewtopic.php?p=320012#320012
I highly recommend it - makes the car so much cleaner looking!
Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Porsche 924 Wide Body LS1 Corvette 500 Horsepower Engine
PostPosted: Sun Jun 26, 2011 1:23 am    Post subject: Reply with quote
Bit, how was it done?
AppleBit
PostPosted: Sun Jun 26, 2011 2:11 am    Post subject: Reply with quote
fiberglass sunroof molded with the metal. However that is done I have no clue
