Posted: Fri Jun 10, 2011 5:05 am Post subject: Zinc pRon! |
*Clicky*
Posted: Fri Jun 10, 2011 6:02 am Post subject: |
Hope you dont plan on tracking the car with those calipers.
The temp will destroy that coating..... _________________ 3 928s, |
bnoon
Joined: 12 Oct 2009 Posts: 607 Location: West Des Moines, IA USA
Posted: Fri Jun 10, 2011 8:01 am Post subject: |
| Lizard wrote: | Hope you dont plan on tracking the car with those calipers.
The temp will destroy that coating..... |
How so? I've tracked my powder coated calipers and never had any issues and the rotors themselves are zinc coated which get much much hotter than the brackets.
Back to Rasta: Did you send them out to be done, or get a kit to do them yourself? I've been thinking about the Caswell kit since I had luck with some of their other kits... _________________ '80 924 Turbo - SOLD!
Porscheless  |
Martijnus
Joined: 29 Dec 2006 Posts: 2019 Location: Netherlands
Posted: Fri Jun 10, 2011 8:36 am Post subject: |
Looks brand spanking new!
And it still will in ten years. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Killed her at the Nurburgring, Porscheless at the moment |
Harm
Posted: Fri Jun 10, 2011 9:18 am Post subject: Re: Zinc pRon! |
| Rasta Monsta wrote: |  |
Looks sweet!
What would be the approximate weight of that bag of bolts, Rasta?
I need a weight figure to do inquiries at some zinc services nearby.
Regards, Harm. |
Posted: Fri Jun 10, 2011 12:40 pm Post subject: |
| Lizard wrote: | | The temp will destroy that coating..... |
Uhhh just like they left the ATE factory. _________________ Toofah King Bad
Posted: Fri Jun 10, 2011 12:46 pm Post subject: |
| bnoon wrote: | | Did you send them out to be done, or get a kit to do them yourself? |
Too cheap (and toxic) to do them yourself. . .$45 for a 5 gallon bucket. _________________ Toofah King Bad
ptheskil
Posted: Fri Jun 10, 2011 10:32 pm Post subject: |
Lizard may have a point here. It looks like a passivated zinc chromate finish. As a general rule these start to degrade at around 125Celsius.
OEM finishes on mechanical parts are usually only designed to prevent corrosion during the showroom phase of a car's life.
Obviously, the corrosion prevention performance of an individual part will depend on thickness, chemical make-up, service conditions of the part... in question. Check out any OE calipers on most vehicles after about 24months and they don't look good.
Will be interesting to see how these last. _________________ 1981 931 series2 Euro spec |
Ian89C4
Posted: Sat Jun 11, 2011 5:46 am Post subject: |
Looks great!
Keep us updated on how the finish holds up!
Cheers
Ian _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
Posted: Sun Jun 12, 2011 7:55 am Post subject: |
Powdercoat has a much higher temp resistance than this Zinc coating.
As well for most from the factory, do you think that they were tracked? No.
For street use, I doubt that it will be a problem. However I also cannot confirm as to the treatment that the calipers got from the factory. But I am pretty sure that they were painted with a high temp paint. Nothing more.
Personally, I would consider a ceramic coating on all the caliper parts to help try to prevent heat transfer. _________________ 3 928s, |
joecitizennn
Joined: 12 Sep 2005 Posts: 2096 Location: no mans land
Posted: Sun Jun 12, 2011 2:08 pm Post subject: |
I have been using ceramic bake on spray paint on my calipers. You just stick it in the oven for an hour after the paint dries and it becomes chemical and heat resistant. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
Posted: Fri Apr 27, 2012 12:21 pm Post subject: |
Or, not.
FWIW, it is plating. _________________ Toofah King Bad
ptheskil
Posted: Sat Apr 28, 2012 4:28 am Post subject: |
Fair play. One to you!
Disc is looking a bit thin though - time for a replacement. _________________ 1981 931 series2 Euro spec |
agfisher
Joined: 09 May 2007 Posts: 483 Location: West Hartford, CT
Posted: Sat Jun 23, 2012 5:02 am Post subject: |
I've been thinking about picking up the Eastwood plating kit to do this myself at home. Are there certain metal bits that you should not plate? I remember in another thread that plating can change the way a bold torques. This would give me pause in plating anything critical that I would have to torque.
In addition I have a vibratory tumbler that cleans and polishes stuff up to 10 inches long. I'm thinking I should be able to do that and plate them right after. _________________ 1977 924 N/A Martini Edition |
Martijnus
Posted: Tue Jun 26, 2012 8:32 am Post subject: |
| Rasta Monsta wrote: | | Lizard wrote: | Hope you dont plan on tracking the car with those calipers.
Or, not.
FWIW, it is plating. |
awesome. I was thinking about this thread a while ago so thank you for updating it
On my next porsche I'll get everything taken care of too. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
