does a 1987 plastic fuel tank fit in a 1984 porsche ?
goldhunter_2
PostPosted: Mon Jun 13, 2011 10:28 am    Post subject: does a 1987 plastic fuel tank fit in a 1984 porsche ? Reply with quote
just finally got the transaxle out and pulled the fuel tank out of the 944, it looks worse then I originally expected so I am looking to replace it . I found two fuel tanks online one is metal an one is plastic both are form 1987 Porsche 944, as hard as it is to remove everything just to get to the gas tank a plastic tank that doesn't rust sounds appealing an worth a little bit extra
questions are :
1) will the 1987 Porsche 944 fuel tank fit fit in the 1984 Porsche 944 ? and does it make a difference if metal or plastic ?
2) what year 924 fuel tanks will fit in a 1984 Porsche 944?
1982 Porsche 924
1984 Porsche 944
97 suburban -- tows everything I trailer
WPB Airboat ----- goes anywhere I point it
PostPosted: Mon Jun 13, 2011 10:53 am    Post subject: Reply with quote
Everything I have read says no- only a 924 tank fits a 924.
PostPosted: Mon Jun 13, 2011 11:21 am    Post subject: Reply with quote
Goldhunter please learn to search:
http://www.924board.org/viewtopic.php?t=29582
goldhunter_2
PostPosted: Mon Jun 13, 2011 11:51 am    Post subject: Reply with quote
Paul I do search but if I don't find the exact answer I ask , and probably allot of time it could help know the proper terms or what to search for.
that post is great but leaves me to more question and back to the searching and asking is a 951 plastic tank the same as a 944 plastic tank and if going in the same 944 model just a different year is all that shown in the other post involved
1982 Porsche 924
1984 Porsche 944
PostPosted: Mon Jun 13, 2011 11:59 am    Post subject: Reply with quote
The 944 section of Rennlist may have more info on 944s than here.
http://forums.rennlist.com/rennforums/924-931-944-951-968-forum-70/
PostPosted: Mon Jun 13, 2011 12:04 pm    Post subject: Reply with quote
http://forums.rennlist.com/rennforums/924-944-rennnlist-e-mail-lists/147343-re-plastic-gas-tank.html
goldhunter_2
PostPosted: Mon Jun 13, 2011 12:26 pm    Post subject: Reply with quote
thanks I signed up over there as soon as it is active I will look at those links
1982 Porsche 924
1984 Porsche 944
PostPosted: Mon Jun 13, 2011 12:40 pm    Post subject: Reply with quote
Many of us spend time over there too. The links will tell you the procedure is about the same as Rasta's write up.
goldhunter_2
PostPosted: Mon Jun 13, 2011 9:45 pm    Post subject: Reply with quote
my rennlist account still is waiting the activation permission but I got a answer back form the guy selling the late model 1987 plastic tank for the Porsche 944 and figured it would be good to post it here for reference in case anyone else was ever searching for the answer, I found the answer helpfully for my situation hopefully other will to.
copy of his email response :
"Sorry this tank won't work in your car.The early 944 and 924 used a metal tank and they are different dimensions.Anything can be made to fit but you would have to change too many things.Thanks for looking "
1982 Porsche 924
1984 Porsche 944
PostPosted: Tue Jun 14, 2011 12:08 am    Post subject: Reply with quote
It will fit, you'll just need to weld in the nuts for crossmember and straps. You'll also need a later gearbox with a center mounting hole.
goldhunter_2
PostPosted: Tue Jun 14, 2011 12:23 am    Post subject: Reply with quote
anything will fit ...lol
no that is just to involved for me right now I just simply want to find a tank that doesn't leak and will fit right back in there , this is or rather was a daily driver nothing fancy and has other issues like a power loss on highway so i am just trying to keep it going is all
1982 Porsche 924
1984 Porsche 944
PostPosted: Tue Jun 14, 2011 2:30 am    Post subject: Reply with quote
Thanks for keeping another 924 alive and well.
PostPosted: Tue Jun 14, 2011 4:26 am    Post subject: Reply with quote
Wait, are you looking for a tank for the 84 944 or the 82 924?
Seems like it was a little confusing, based on the replies, to which you're looking for.
I don't know that it makes a difference ultimately, but just wanted to be sure....
You could try car-part.com and call up some of the salvage yards. Most puncture the tanks, but you might get lucky. Also, Craigslist has an auto parts section, so maybe someone is parting one locally to you?
Good luck on the search.
goldhunter_2
PostPosted: Tue Jun 14, 2011 6:09 am    Post subject: Reply with quote
I am looking for a fuel tank for a 1984 Porsche 944 form what I have found they are the same metal tanks that fit the 924 models apparently somewhere in the mid 1987 model Porsche changed to a plastic tank with a different cross member and shape (will not fit without some major work)
my 924 also has a pin hole but the patch works on it the 944 was way to far gone and I gotta replace I'm trying to keep them both going and have issues with both so maybe some people confused which one since I have asked a few questions lately
1982 Porsche 924
1984 Porsche 944
PostPosted: Tue Jun 14, 2011 7:59 am    Post subject: Reply with quote
Gotcha.
Sounds like the plastic tank retrofit isn't too bad to do, in the grand scheme of things.
You might also ask Byron (BVD Motorsports) if he has a tank or any of the retrofit parts.
http://www.facebook.com/media/set/?set=a.277472179512.140883.186854959512
http://members.rennlist.com/racerbvd/http://members.rennlist.com/racerbvd/
http://www.914club.com/bbs2/index.php?automodule=blog&blogid=337&
He might have what you need and he's in Orange Park, Florida, which might help (even if you have to drive the length of the state, heh)
