jessy1984
Posted: Thu May 26, 2011 2:37 am Post subject: play on new rear wheel bearing |
hi i have some play on my new rear wheel bearings i have removed it again checked everything 3 times everything is sitting like it should be
these are bearings from skf a real good brand porsche uses these also
torqued to 300nm even a bit more
now i saw more posts about this but no solution
dous anyone know why this is ?
last time i changed some these bearings was with an NA924 and there was no play
Posted: Fri May 27, 2011 4:43 am Post subject: |
Believe one or more spacers back there can cause excessive play due to wear.
-And pretty sure the main culprit appears here as "6" -
 _________________ "..it's made in Germany. You know the Germans always make good stuff."
jessy1984
Posted: Fri May 27, 2011 7:53 pm Post subject: |
thanks for the responce put this can not be the problem the rings will always be fastend by the central nut even iff its up to 1mm to short
but i found the problem today
the outer wheel bearing from FAG (you can always see the brand on the bearing itself not the package)
i have chaged the inner ring from that bearing bak to the old one and the play is gone |
