Best way to get keys?
MRPETE
PostPosted: Sat May 14, 2011 5:47 pm    Post subject: Best way to get keys? Reply with quote
Hi Guys
I just bought an '81 924 but the guy lost the keys since I picked it up.
First question Does one key fit all?
2nd What fits what?
3rd what is the best way ta git ew Un's? Dealer with a VIN or will(should)
a door lock be the same as the igniton?I have a'77 but this is new haha
to me'
Got A SMOKIN deal under 70 thou on the clock and it works mint MINT
interior Dash PERFECT AIR blah blah blah
I've been away for a while but I'm back!
Thanks to all that want to respond.
MrPete
77 824
81 824javascript:emoticon('')
Lots of Corvairs
'77 924
"81 924
Lots o' Corvairs
PostPosted: Sun May 15, 2011 8:06 am    Post subject: Reply with quote
Yup, one key fits all. That way when your 924 doesnt start, you can look for another in the parking lot and get home.
3 928s,
PostPosted: Sun May 15, 2011 9:33 am    Post subject: Reply with quote
Lizard welcome back.
PostPosted: Sun May 15, 2011 9:35 am    Post subject: Re: Best way to get keys? Reply with quote
MRPETE wrote:
Hi Guys
2nd What fits what?
to me'
The ignition key fits the ignition, the doors, and the hatch.
Check with a dealer, or buy new/used locks.
Jakkq
PostPosted: Sun May 15, 2011 1:05 pm    Post subject: Reply with quote
I had bought some replacement door handles through Porsche. It came with two separate keys for each door, and a backup set.
1979 Porsche 924- Snailshell
http://porsche924workblog.blogspot.com/
MRPETE
PostPosted: Sun May 15, 2011 5:11 pm    Post subject: Reply with quote
I;d like to keep the keys current to what was stock with PORSCHE
if I was to lose a keyIN TIMBUKTU it would be handy not to steal my own
car.Any experiences???
MrpETE
'77 924
"81 924
Lots o' Corvairs
PostPosted: Mon May 16, 2011 3:44 am    Post subject: Reply with quote
You have a couple of options.
#1 Take a doorhandle off, run it to a locksmith, and have a key made. The risk in this method is that the if the doorhandle was replaced at some time, and was not rekeyed, you still won't have a key that fits the ignition lock cylinder.
#2 Take a doorhandle off, remove the lock cylinder, and read the numbers/marks on the tumblers to create a key coding list, then find a locksmith who has the tool to create a key from the tumbler numbers. The risk here is the same as #1, so you might want to reduce the risk by removing both doorhandles to see if the tumblers (and the key that they would work with would be the same).
Removing and installing a doorhandle on a 80/2 and newer car is not the same as on your 77. The 77 doorhandles just slip into the holes on the exterior of the door. On the newer doorhandles the linkage has to be snapped on from the outside of the door, before the handle can be mounted, while holding the handle close to the holes in the door (awkward).
Marlando
PostPosted: Mon May 16, 2011 9:31 pm    Post subject: Reply with quote
I had similiar situation that the keys couldn't be found by PO. I took rear glass lock to locksmith and they made keys to suit. Then all things done right and fingers crossed they also fitted doors and ignition. Well worth a try before replacing locks and ignition barrel.
'79 924.
4 speed manual.
Formerly Indiana Red, now Green.
PostPosted: Mon May 16, 2011 10:06 pm    Post subject: Reply with quote
^that is funny !!
MRPETE
PostPosted: Thu May 19, 2011 4:26 pm    Post subject: Reply with quote
thanks guys
pulled the ignition got the code gonna' get new key and put everything
back to correct
update:all electrics are A ok and good to go
a FEW MOON roof issues(broken plastic crap)Any suggestions?Weatherstrip
ETC Not crazy about it but what the hey
Thanks again
Mrpete
'77 924
"81 924
Lots o' Corvairs
