Themostat
diettmann
PostPosted: Wed May 11, 2011 1:58 am    Post subject: Themostat Reply with quote
hi i have a 1980 931 i need to change out the thermostat cause their not fun when they overheat. Where i could find it on the motor? also sometime down the lin i need to fix the syncro from first to second gear could someone tell me where i could find the part or part number or something or am i just going to have to get a whole new trans?
PostPosted: Wed May 11, 2011 5:11 am    Post subject: Reply with quote
Grab a Haynes manual and it will give you the procedure.
The syncro's are tricky, but I think Ideolas garage has a kit for the 931 transaxles.
924.org has some info as well, check out the tech section.
