Distributor vacuum advace hose connection
jbwheele
PostPosted: Mon Apr 18, 2011 6:27 pm    Post subject: Distributor vacuum advace hose connection Reply with quote
Hi all Ive got my beast on the road but I am having trouble under boost /load with pedal depressed. The car is staggering and backfiring I havent caheck the timing correctly so I bought myself a timing light , now my problem is , the two vac lines to the distributor one pushes and one pulls ? do they both connect to manifold vacuum? and where? Haynes is a bit vague.....help
Joe
82 932 Stripped bare full rebuild
80 932 GT Lookalike Engine S2 swap
jbwheele
PostPosted: Mon Apr 18, 2011 8:00 pm    Post subject: Hey fixed Reply with quote
Thanks Bockscar picks up very well ! Lots of PINKING , best put a boost gauge on so I can see whats happening.
Joe
PostPosted: Tue Apr 19, 2011 1:39 am    Post subject: Reply with quote
Series 1 (non-DITC) vac lines - http://farm2.static.flickr.com/1390/739762232_e495753b55_o.jpg
Vac advance hooks uo upstream of the throttle, while retard hooks up downstream -
