markmazour
Joined: 29 Sep 2008 Posts: 37 Location: Vermillion, South Dakota
Posted: Mon Mar 14, 2011 7:57 am Post subject: Front Wheel Bearing issue wrong size? |
I have a 1982 Porsche 924. I purchased front wheel bearings and seals from Pelican. I have finally gotten around to installing these and they do not seem to be correct. Please review the attached photos. As you can see these bearings and seals are considerably larger than the ones that are on my car. Along with being too large for the hub they are also loose and sloppy on the shaft.
I have included a shot of the tag on my car to confirm that I am indeed selecting the correct parts for my vehicle.
Were the wrong parts selected on my part or were the wrong parts picked from their inventory? Or do I have an odd vehicle?
I ordered Front inner 999-059-098-00-M92, outer 999-059-065-00-M34 and this seal 477-405-641-M30
 _________________ Mark
1982 Porsche 924 Indiana Red Metallic SOLD
2001 BMW 325i Silver SOLD
2011 BMW335is Space Gray 6mt |
Posted: Mon Mar 14, 2011 11:20 am Post subject: |
I haven't checked your part numbers against PET yet, but my guess is that you ordered parts for the five lug setup, and not for the four lug which you clearly have. Pelican's site can be a bit difficult to navigate for 2.0L 924 stuff...the only stuff they list is for the 924S/944 2.5L cars unless you specifically know the correct part number to look up and order. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Mon Mar 14, 2011 1:44 pm Post subject: |
Yep, send them back and get them for the 4-lug cars.
Another option is to order them from RockAuto.com as their database is a bit easier to navigate for more common wear parts like those. _________________ Stefan
markmazour
Posted: Tue Mar 15, 2011 10:45 pm Post subject: |
Sure enough I checked the PET, should have done that in the first place, and I do indeed have the front wheel bearings and seals for a 5 lug hub. Good news is that the kind folks at Pelican are going to let me swap for the correct parts. Did I mention I had been sitting on them sine 3/3/2010?
I was also concerned that I had the wrong bearings for the rear as well, but they are the same for the 4 and 5 lug on the rear.
FWIW I am in the process of a replacing all wheel bearings front and rear and rebuilding the front control arms, bushings and ball joints.
Been having issues with the front vibrating at 60+ mph and the rear making a funny rubbing noise when turning at low speeds <35. _________________ Mark
Duncan
Joined: 04 Nov 2002 Posts: 425 Location: Delft, The Netherlands
Posted: Wed Mar 16, 2011 12:26 am Post subject: |
I was wondering how the process of replacing the front wheel bearings differs from the setup of say the 944 where there is an actual wheelhub to house the bearings as opposed to the 924 where they are set in the rotors?
The hub of the 944 seems to be aluminium vs the cast iron material of the 924 rotors, or not?
Duncan _________________ 1983 NA Alpineweiss since 2001
Peugeot 205 Generation |
Duncan
Posted: Wed Mar 16, 2011 12:30 am Post subject: |
And another thing:
My cross reference says that the FRONT wheel bearings of the 924 are the same as the REAR wheel bearings of a VW golf (or rabbit as you call it)?
Is this true?
