tuf-924
Posted: Thu Mar 10, 2011 9:33 pm Post subject: Fuel breather |
Ay everyone I'm Andrew from Australia and I was wondering on my 924 if there was a fuel breather in my fuel tank? Because I filled it up a full tank of fuel today and parked on the cerb then noticed that my fuel was leaking but it was on the side where I don't fuel up. Would you all think it's leaking or just over filled??
It doesnt leak when Its tilted the other side! _________________ Vass... |
Posted: Fri Mar 11, 2011 2:21 am Post subject: |
Check out the diagram of the tank in PET (PDF parts catalog). Short answer, yes, there are numerous vent hoses and a plastic "expansion tank" that could be cracked/leaking. These tanks have also been known to crack along the depressions stamped into them at the factory. . .check out the discussion over at Pelican.
IMO, the best way to accurately diagnose at this point is for you to drop the tank. _________________ Toofah King Bad
staticsan
Joined: 19 Jan 2009 Posts: 450 Location: Sydney, Australia
Posted: Sat Mar 12, 2011 5:05 pm Post subject: |
I discovered that when filling it up, unlike in a modern car, you should stop at the first click. Any further and the fuel is in the filler tube where it's not supposed to stay.
I found this when I filled it up on the way to an emissions test. Fuel vapour was one of the failure points. And when I got it home and we pulled the filler tube apart, the fuel level as at the tippy-top of the tank. Clearly, I'd simply overfilled it.
Wade. |
Posted: Sun Mar 13, 2011 2:40 am Post subject: |
A reliable cheap-easy work-around until it's fixed correctly is - from empty (low fuel light lit), put in only 10 gallons.. (The round number also makes it easy to get your average mpg - just watch for the light to come on again, and note the elapsed mileage.)
This works for the just-filled-up-fuel-smell problem. Should work with most small upper-tank leaks too. -But obviously should fix any fuel leak quickly.. _________________ "..it's made in Germany. You know the Germans always make good stuff."
tuf-924
Posted: Sun Mar 13, 2011 8:02 pm Post subject: |
Cheers thanks guys _________________ Vass... |
