Tor K Refsland
Posted: Mon Apr 02, 2012 11:23 pm Post subject: Alternator Belt issue |
I've had a lot of trouble with my alternator belt lately... It just won't stay tight! Every time I tighten it, it runs nicely for a little while (about 100 km) and than it pulls itself loose again. I've changed the belt several times because the old one broke while driving...
It all started after some electrical problems after i changed the starter, and I'm wondering if it might have something to do with the alternator?
I'm guessing the alternator has more friction than it's supposed to and therefore the belt won't stay taught?
Have anyone else had a similar problem or does anyone else have any idea what else could be wrong?? _________________ '84 924 NA
'81 924 Carrera GT (part ownership) |
Posted: Tue Apr 03, 2012 12:22 am Post subject: |
Faulty mounting hardware. I would pull the bolt that tightens the alt in place and replace it with new, and make sure everything is there (1 bolt, 1 flat washer, 1 spring washer, 1 nut). _________________ Toofah King Bad
Joined: 29 Jul 2001 Posts: 9075 Location: Royal Oak, MI, USA
Posted: Tue Apr 03, 2012 1:03 am Post subject: |
Also the rubber bushings at the pivot often fall apart and must be replaced. _________________ Vaughan Scott
