Still having problems
chaparral2f
PostPosted: Thu Feb 24, 2011 9:02 am    Post subject: Still having problems Reply with quote
I was asked to post pics of how my timing was set. So now that I finally figureds out how to post here they are.
http://www.flickr.com/photos/chaparral2f-z31/5471799967/in/photpstream/
http://www.flickr.com/photos/chaparral2f-z31/5472380338/in/photostream/
I checked the fuel pump output and it is @1500 cc/30sec the fuel delivery pressure is well within the range set in the manual I'm going to check and see if the WUV is opening, and then make sure the injectors are spraying correctly. I keep asking, but haven't gotten an answer as to whether the cqr lacking a fuel accumulator would cause these problems
If you're gonna be stupid, you gotta be tough.
1980 Porsche 924
1997 GMC Jimmy (DD)
1984 300zx Tube chassis, Jag suspension, 400hp sbc
dpw928
PostPosted: Fri Feb 25, 2011 2:39 am    Post subject: Reply with quote
The second picture indicates, to me, that the rotor is not pointing to the number one plug wire. It should point to a notch cut in the metal portion of the distributor so when the cap is installed the number one plug wire is above the notch.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
chaparral2f
PostPosted: Fri Feb 25, 2011 5:56 am    Post subject: Reply with quote
That could be. the Haynes book says: "Align the line on the rotor with the scribed mark on the distributor housing."
Of course that is the Haynes manual, and I don't have a lot of faith in their information.
1980 Porsche 924
1997 GMC Jimmy (DD)
Slam
PostPosted: Fri Feb 25, 2011 8:04 am    Post subject: Reply with quote
Dennis is right. You're about one gear off/behind time on that rotor. Easiest fix is to pop the distributor off and advance it that one tooth... Well, it LOOKS like one tooth from here.
PostPosted: Fri Feb 25, 2011 8:49 am    Post subject: Reply with quote
where is your flywheel mark and oil pump pulley marks when the cam is TDC?
No accumulator would cause fluctuations in your fuel pressure and be a bitch to start when hot.
chaparral2f
PostPosted: Fri Feb 25, 2011 11:27 am    Post subject: Reply with quote
There is a mark on the dist housing, about 1/16 from the electric plug. I'll pull the dist, and move it to the notch where the cap fits. The mark on the oil pump pulley, and the flywheel are exactly on the pointers where they should be. I replaced the injectors, but I'm going to pull them and take them to be checked.
Thanks for the information on the accumulator, and tips on the timing,
Joe
1980 Porsche 924
1997 GMC Jimmy (DD)
