Kongle
Posted: Mon Feb 21, 2011 10:59 am Post subject: 924 cluth problem help needed please |
Hi .. i have just purchased a 1981 924 base car so I don't know the history of the car.
I have found I have to push the clutch peddle all the way to the floor (almost like through the floor) to shift into 1st and sometimes 2nd grinds if the clutch is not all the way to the floor.
3rd / 4th / 5th gear are fine, I only need to push clutch normally to shift (engage / disengage clutch )
Reverse grinds all the time even if I push the clutch all the way to the floor.
Does this sound like a throw out bearing problem, bent / cracked clutch fork or something else ?? How do I adjust the clutch for travel ?? It is cable system. Link or explanation would be great help
I was thinking wouldn't a bent clutch fork or bad throw out bearing affect all gears .. ie engage and disengage of the clutch
Thanks for helping me out, much appreciated |
Posted: Mon Feb 21, 2011 6:01 pm Post subject: |
Syncros are shot. Sorry  _________________ Stefan
Posted: Tue Feb 22, 2011 3:33 am Post subject: |
Cable properly adjusted? Did you buy a manual? _________________ Toofah King Bad
Posted: Tue Feb 22, 2011 5:02 am Post subject: |
Uh, if it grinds in first, second and reverse, but not third, fourth and fifth, then adjusting the cable isn't going to fix it. That sounds like a problem in the more commonly abused gears and syncros.
I guess it won't hurt to adjust the clutch cable per the manual. At least you'll know its where it needs to be.
How are the shifter linkage bushings? Much slop in the action?
I would try changing the oil in the gearbox (if you haven't done it already) You can see how much shiny metal comes out.
You'll likely need to refresh the box, clutch cable and shifter bushings and maybe the torque tube bearings and clutch (depending on what you find once you dig in.
I would start looking at transaxle refresh parts or a spare transaxle and then practice your rev-match shifting to cut down on the grinding until you can fix the transaxle. Sorry  _________________ Stefan
Posted: Tue Feb 22, 2011 5:23 am Post subject: |
CPP rides again!
Good point about those reverse synchros, tho!
(I know, I know. . .KYA!) _________________ Toofah King Bad
Posted: Tue Feb 22, 2011 6:53 am Post subject: |
The '81'd have an Audi (non-Getrag, non-snailshell) gearbox - so at least less likelyhood of the grindy synchro problem, no?..
I'd keep the faith and assume clutch adjustment problem until proven otherwise. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Kongle
Posted: Tue Feb 22, 2011 9:16 am Post subject: |
Hi, thanks everyone for being so helpful.
Whats the best tool to adjust the clutch cable, I find a box wrentch is too long to turn ?
I found by putting in 1st and then Reverse this prevents the grinding when I just put it in reverse.
I thought the reverse don't have synchro gear ???
Thanks |
Posted: Tue Feb 22, 2011 11:52 am Post subject: |
Your clutch is not fully releasing. Adjust it before you cause very expensive tranny damage. _________________ White 87 924S "Ghost"
tomcooper
Joined: 17 Feb 2004 Posts: 301 Location: Waterloo, Nebraska
Posted: Tue Feb 22, 2011 2:23 pm Post subject: |
You might want to take a look at the point the clutch cable goes through the firewall. A not uncommon problem is the firewall failing at that point and the clutch going out of adjustment. You can adjust it for a while, but then it gets to the point where the firewall will have to be repaired.
Casper currently has that problem.
Tom _________________ Casper and Big Red, both 1980 NA
Black Bart, 1990 944 S2 Cab |
Duncan
Joined: 04 Nov 2002 Posts: 425 Location: Delft, The Netherlands
Posted: Tue Feb 22, 2011 8:42 pm Post subject: |
I also had the problem that standard box wrenches were to long to move around. I bought two cheap wrenches and cut them in half with a hacksaw.
In the past I also used a small adustable wrench ( a bahco). _________________ 1983 NA Alpineweiss since 2001
Peugeot 205 Generation |
Kongle
Posted: Mon Feb 28, 2011 6:57 pm Post subject: |
Thanks you guys, you are the best, thanks for all your help and suggestions
I think I still need a clutch 101 lesson -
I have adjusted the clutch cable .. it does feel better now, but I feel I need a new clutch kit. I can find one from local shop by LUK.
Anyone had any experience with LUK clutch kits ??? its cost about 5x less than Sash OEM
I don't know if I need to replace the clutch
From the inspection hole (clutch normal position)
From another angle
This is the throw-out bearing (clutch normal position)
Another view of throw-out bearing
And a video
http://www.flickr.com/photos/kongc/5485251838/
Please let me know what you guys think ??? Thanks in Advance |
Kongle
Posted: Mon Feb 28, 2011 8:04 pm Post subject: |
.. and this was the best cable adjustment I can get ... if I adjust anymore the clutch won't release and the car will not stall in 1st gear and no torque, if I adjust any less I will need to put my foot to the floor and hard shift into 1st gear.
Thanks again. What do you guys think is the problem ??? ... and how does my clutch look ? |
Posted: Tue Mar 01, 2011 2:28 am Post subject: |
Did you follow the correct spec for adjusting the clutch? I think on an NA it involves measuring pedal free travel? _________________ Toofah King Bad
Brockoli
Joined: 06 Feb 2007 Posts: 621 Location: Edmonton, Alberta, Canada
Posted: Tue Mar 01, 2011 6:49 am Post subject: |
^+1
I think it is 3/4 - 1'' of free play. I used a ruler to measure it from the floor board. Its kind of hard to measure accurately but close counts. _________________ '80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
'79 924 Sebring Edition(Sitting) |
Kongle
Posted: Tue Mar 01, 2011 8:16 am Post subject: |
| Hi .. are you guys able to take a picture of the cluth play adjustment screw for me please ??? |
