Squeal/squeak from rear wheel
PorscheLover86
PostPosted: Mon Jan 24, 2011 12:04 am    Post subject: Squeal/squeak from rear wheel Reply with quote
Recently i've developed a small squeak that turns into a squeal when making gradual left turns at speed. i took the wheel off and realized it was horribly out of balance. but after replacing the wheel i still hear the squeal/whir. not as bad mind you. No play in the bearings and the axle shafts are pretty new.. any ideas as to what the noise is?
Black '77 924 N/A
joecitizennn
PostPosted: Mon Jan 24, 2011 2:20 am    Post subject: Reply with quote
It is not power steering related is it?
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
Captain_Kirk
PostPosted: Mon Jan 24, 2011 4:32 am    Post subject: Reply with quote
Not unless he has one of those ultra rare four wheel steering models.
1977 924na BlackSeaRD.com Torque Tube SuperBearings, Xenon air dam, 200# Weltmeister springs, Bursch header, 944 exhaust, Audi throttle body
jacobscott209
PostPosted: Mon Jan 24, 2011 12:25 pm    Post subject: Reply with quote
brakes? or the center nut might be a little loose if it was taken off at any point. It's supposed to be at something like 220 ft lbs torque. I had mine at something like 90 lbs and it wooshed and squeaked untill it was corrected.
joecitizennn
PostPosted: Mon Jan 24, 2011 2:34 pm    Post subject: Reply with quote
Ohhh I see the title says REAR wheel. I suppose a squeak when turning could also be a lack of elbow grease.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold
PorscheLover86
PostPosted: Tue Jan 25, 2011 5:06 am    Post subject: Reply with quote
Well i have rear drums.. so what part of the brake would squeak or whoosh.. or whir.. or make any other noise?
Black '77 924 N/A
PostPosted: Tue Jan 25, 2011 6:08 am    Post subject: Reply with quote
Rear wheel bearings are going dry.
When you replaced the axle shafts, did you inspect or replace, and repack the wheel bearings with a good grade of synthetic grease?
The original grease should have been replaced long ago, and if not, heat causes it to break down. This is especially bad on the left side because of the exhaust system.
While you are in there you should clean, inspect, and repack, the cv joints as well.
PorscheLover86
PostPosted: Tue Jan 25, 2011 7:08 am    Post subject: Reply with quote
the previous owner replaced the shocks and shafts before selling it to me. so i'm not sure about the bearings. what do i have to do to lubricate the bearings?
Black '77 924 N/A
PorscheLover86
PostPosted: Tue Jan 25, 2011 7:30 am    Post subject: Reply with quote
I drove it today.. the noise is akin to irrrrrr...irr.irr.irrrrrrrr.. irr.irr..
is that what a dry bearing would sound like?
Black '77 924 N/A
PostPosted: Tue Jan 25, 2011 9:35 am    Post subject: Reply with quote
You could have a piece of dirt between the drum and the brake shoe, or a brake shoe is dragging.
Try adjusting the rear brake shoes (which should be done regularly) and see if the noise changes at all.
Either way, you'll likely get to pull the rear bearings and drums off to clean and service the system.
Pretty similar to a super beetle's rear brakes and suspension, lots of info on that on the 'net.
rat
PostPosted: Tue Jan 25, 2011 2:41 pm    Post subject: Reply with quote
Just remember to get yourself a 6 foot bar and a fat bloke to get the damn hub nuts undone..
PorscheLover86
PostPosted: Wed Jan 26, 2011 12:07 pm    Post subject: Reply with quote
Well. since i have neither the time, tools or patience required to do it. i'll simply pay a mechanic too.. i suppose 150 bucks isnt the end of the world.
Black '77 924 N/A
PorscheLover86
PostPosted: Sat Feb 05, 2011 1:31 am    Post subject: Reply with quote
Bearing nut not torqued properly.. just paid 55 dollars for a man to turn a wrench.. fantastic.. but at least the problem is fixed and the noise has abated.
Black '77 924 N/A
