engineer.white
Joined: 19 Aug 2008 Posts: 61 Location: New Bern, North Carolina
Posted: Fri Dec 31, 2010 12:50 pm Post subject: 924 2.0 Oil Pickup compared to 944 pickup |
As I am in the process of rebuilding a 1982 931 I noticed that the 944 oil pan has a quite extensive oil baffle scheme where the 924 does not. Has anyone done anything to improve the 924 oil pan other than the crank scrapers. I notice that Lindsey Racing has a kit to add a flapper door to the 944 pan as well as extending the oil pickup lower in the pan. Seems like some of these mods would trickle down to the 924 world. The 944 pickup seems much less restrictive than the 924 one as well.
David _________________ 1981 924 turbo/931
1982 924 turbo/931
1986 911 turbo/930 |
Joined: 29 Jul 2001 Posts: 9080 Location: Royal Oak, MI, USA
Posted: Sat Jan 01, 2011 12:18 am Post subject: |
The baffling in the stock 924 oil pan is actually quite good, IMO - certainly compared to most stock pans. Mainly it just doesn't have the sort of built-in (almost) windage tray that the 944 has.
We don't have any oil pressure issues, unless you want to count too-high pressure! Just a question of controlling oil flow in those long left-handers - which is where the crank scraper does a wonderful job, since it functions as a baffle as well.
Plus it's only $50 in its cheapest configuration... _________________ Vaughan Scott
gla924sem
Joined: 08 Nov 2002 Posts: 405 Location: Taylor, Michigan
Posted: Sat Jan 01, 2011 1:06 am Post subject: 924 |
If you're looking for the crankscraper and windage tray.......Ideola can get the for you.
Am installing during my current rebuild along with an AccuSump
Its about a 4-5 week delivery on the parts throught Ideola
http://garage.ideola.com/ |
leadfoot
Posted: Mon Jan 03, 2011 5:37 pm Post subject: |
P.S
Do not forget to drill / cut an access hole for the oil dip stick.
It does say this in the installation guide from I.J but is a gotcha as there are no provisions for this in the design.
Stu _________________ 1981 ROW 924 Turbo -
carbon fiber GT mish mash
