Converting early to late style front sway bar ?
Dutch924-racer
PostPosted: Sat Dec 18, 2010 2:01 am    Post subject: Converting early to late style front sway bar ? Reply with quote
I want to convert my early front sway bar to late style.
I have all the parts (ne style trailing arms/ sway bar and mounts).
Is the swaybar mount welded on the chassis in te good place or are the later style ones located different ?
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
BionicBalls
PostPosted: Sat Dec 18, 2010 1:51 pm    Post subject: Reply with quote
Later style is bolted to the frame rails. Our cars have the indentions in the frame rail if you look closely. I welded mine on. I also took the chance to make a little added support and designed a bracket that I welded to the verticle part of the frame rail right before the control arm mount. If I get a chance I'll try to snap a pic.
1980 924 NA
1982 931
