Distributor Position
eric62221
PostPosted: Tue Nov 23, 2010 1:05 pm    Post subject: Distributor Position Reply with quote
Been looking through pics online and realized that the distributor on my 924 is on wrong. From reading it can go on in two different positions, and looks like mine is on wrong.
So what is involved with putting it on correct and what will it do to the engine for being wrong.
Here is a pic for reference.
PostPosted: Tue Nov 23, 2010 1:49 pm    Post subject: Reply with quote
What will having the distributor mounted in the high (incorrect) position do?
Obviously something is going to hit the hood, and rub, eventually shorting out the ignition system.
What should you do? Remove the distributor and remount it in the correct lower position, then reset the ignition timing.
MRPETE
PostPosted: Tue Nov 23, 2010 3:30 pm    Post subject: Reply with quote
NOOO don't remove it Just rotate it 90 degrees or whatever it takes and put your plug wires in the appropriate location check the timing the motor will never know the difference(but you'll feel better
'77 924
"81 924
Lots o' Corvairs
oldmanwintersret
PostPosted: Wed Nov 24, 2010 12:02 am    Post subject: Reply with quote
I just got done rebuilding my ignition system and indexing my dizzy. Follow exactly gohim stated. Reuilding the ignition system was no fun. gohim helped me to get mine to run, he knows what he is talking about. From my experience I agree with him 100%. Just rotating the dizzy 90 degrees is just going to throw the timing off.
1982 Porsche N/A
PostPosted: Wed Nov 24, 2010 8:10 am    Post subject: Reply with quote
this is a picture of the dissy housing with home made gasket which attaches to the head.
you will notice there is two bolt positions for the bolts.
this pic show the housing mounted in the correct position.
This will put the ign timing out so check it with a timing light when completed
Rich H
PostPosted: Wed Nov 24, 2010 8:16 am    Post subject: Reply with quote
What Ozzy said.
Undo the bolts and re-align the casting. Only a couple of bolts.
