Jakkq
Joined: 29 Sep 2008 Posts: 810 Location: Omaha, Nebraska
Posted: Sun Nov 21, 2010 12:11 pm Post subject: muffler bracket |
So the muffler snapped off from the bracket it was connected to. This metal piece appears to be done for, but what should I look for to replace this piece? For now ill have to see if I can bungie it.
I think its two brackets. The part that came off was from the smaller bracket. _________________ 1979 Porsche 924- Snailshell
http://porsche924workblog.blogspot.com/ |
datatrain
Posted: Mon Nov 22, 2010 12:45 pm Post subject: |
Been there... a pic would be good _________________ '78 924 NA with Collector plate
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR |
D Hook
Posted: Mon Nov 22, 2010 11:46 pm Post subject: |
IIRC, the bracket that probably broke is the one that goes around the muffler, correct? It hangs off another bracket that's bolted to the frame of the car, right? I seem to remember the strap going around the muffler as being a piece of plumbers strap or something like that, in which case you can buy a roll at the local hardware store and replace it. Or you can put up a post on the For Sale board and see if somone has an original one laying around they'd like to get rid of.
The bracket that's bolted to the frame of the car is still intact, right? _________________ '80 924 n/a SOLD |
Jakkq
Posted: Thu Nov 25, 2010 2:53 am Post subject: |
You gonna DIY or replace pieces the OEM route.
Once I was able to redrill 4 holes in the pieceof
bracket that mounted to the frame, after that
I just cut, drilled piece of flat stock then wrapped
the muffler . . do you still have the rubber hanger
brackets ??? _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
