Jakkq
Joined: 29 Sep 2008 Posts: 810 Location: Omaha, Nebraska
Posted: Sat Oct 30, 2010 3:29 pm Post subject: Cigarettle Lighter Socket Workaround? |
Okay so I have tried quite a few different car chargers, but nothing fits snug into the socket. I am guessing the socket is not US?
In any case, I am pretty certain the socket is non-functional.
What should I look for about installing a socket that will work with the car, and also work to charge items such as my GPS and Phone? _________________ 1979 Porsche 924- Snailshell
http://porsche924workblog.blogspot.com/ |
thirdgenbird
Joined: 29 Feb 2008 Posts: 367 Location: Pella, IA USA
Posted: Sat Oct 30, 2010 3:43 pm Post subject: |
ive used mine before but as you discovered, most plugs fit pretty loose.
i am thinking about hooking up a cellphone charger behind the dash so i can just run a micro usb cable in an inconspicuous location. i would do the same with the gps. i hate exposed wires hanging everywhere... _________________ 17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel |
Posted: Mon Nov 01, 2010 1:17 am Post subject: |
You can install a US version in the same space and solve the problem for less than $10. _________________ White 87 924S "Ghost"
