Pilot bearing
the_mad_electrician
PostPosted: Wed Sep 29, 2010 9:54 am    Post subject: Pilot bearing Reply with quote
Does anyone know where I can get a pilot bearing that is considerably cheaper than $70?
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
PostPosted: Wed Sep 29, 2010 12:10 pm    Post subject: Reply with quote
Not one that you would actually want to use..... :p
3 928s,
the_mad_electrician
PostPosted: Wed Sep 29, 2010 6:20 pm    Post subject: Reply with quote
well that sucks
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
Rich H
PostPosted: Wed Sep 29, 2010 6:57 pm    Post subject: Reply with quote
Just measure it up, it's just a needle bearing.
Search for spigot bearing on here I'm pretty sure I posted the dims of the one I used.
It cost about £3
924-76
PostPosted: Wed Sep 29, 2010 9:55 pm    Post subject: Reply with quote
Performance product website seems to be down at the moment but I could find the following in there catalog:
- Needle cage for $8.95 part #924270 or
- Needle cage with outer housing for $73.99 part #904491
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
PostPosted: Wed Sep 29, 2010 11:15 pm    Post subject: Reply with quote
Pretty sure there were differing, and incompatible pilot/spigot bearings used in different 924s. It's been researched and information posted here in the past. I'd try finding those post/s to verify before ordering.
Slam
PostPosted: Thu Sep 30, 2010 1:47 am    Post subject: Reply with quote
All the N/A pilot bearings are the same needle bearing, but trust me - it's worth it to get the whole assembly. First you gotta get the old assembly out of the car without trashing it (a feat in itself), then you'd have to re-use the PB seal, which you will destroy getting the needle bearing out of the housing. If anyone has a source for that seal by itself you'll be fortunate. It's easiest and best to just spend the cashola and get the whole assembly.
Check the How-To section. I put up a thread about getting that sucker out and Stefan (fiat22turbo) added some great stuff to it.
http://www.924board.org/viewtopic.php?t=32178
Rich H
PostPosted: Thu Sep 30, 2010 4:15 am    Post subject: Reply with quote
I bought a shaft seal to go with the bearing, or you can buy a bearing with an integral seal... Easy!
I use simplybearings.co.uk
Slam
PostPosted: Thu Sep 30, 2010 5:02 am    Post subject: Reply with quote
You know, it would be worth it to find a roller bearing for this application. Anyone gone that route?
Rich H
PostPosted: Thu Sep 30, 2010 5:14 am    Post subject: Reply with quote
You mean ball bearing? I think you'll struggle to find one that will fit...
Rich H
PostPosted: Thu Sep 30, 2010 5:15 am    Post subject: Reply with quote
Details of N/A pilot/spigot bearing:
http://www.924board.org/viewtopic.php?t=22834&highlight=spigot
