Clutch power handling capabilities?
Euro924S2
PostPosted: Wed Sep 29, 2010 11:21 pm    Post subject: Clutch power handling capabilities? Reply with quote
Hi guys, I'm looking into clutch options for my supercharger project (240bhp target) - I need to decide on a clutch so I can then decide on a gearbox plan - keep my audi 5 speed (remember i'm in UK) 20mm input from the NA, swap in all the donor parts from the 931 snailshell (which most likely will need a rebuild) or swap in a 944/951 box and TT - so my question is ....
1) What BHP and torque have people been able to run with an 2.0L NA standard clutch?
2) What BHP and torque will a 931 standard clutch handle?
3) What BHP and torque will a Bronco II clutch handle??
4) Any experience from using 'Staged' clutches on a fast road car? (OK or a PITA in traffic??)
Cheers, John.
UK spec '83 N/A with 931 motor with Eaton MP62 'charger @ 15psi. EFI - 565cc inj. Standalone Adaptronic ECU. 951 FMIC. Ally rad. Twin throttle. Recirc valve. Custom manifolds and CAI. 232bhp
PostPosted: Fri Oct 01, 2010 5:27 am    Post subject: Reply with quote
From my personal experience:
-931 clutch holds 200-230 HP no problem.
-944 gearbox will hold for sprinted driving on the streets (200-230HP)
I think that if you want over 200HP you have to swap the 944 torque tube and gearbox.
flosho
PostPosted: Fri Oct 01, 2010 6:05 am    Post subject: Reply with quote
I was thinking about getting into a uprated spec clutch for a bronco II for my build..
[This Space For Rent]
endwrench
PostPosted: Thu Oct 07, 2010 1:18 pm    Post subject: Reply with quote
You might take a look at this thread:
http://www.924board.org/viewtopic.php?t=22052
It has some power handling numbers and considerations on a supercharged NA motor. I also converted to a 944 trans and tube at the same time.
Todd
Scorpio
PostPosted: Thu Oct 07, 2010 8:47 pm    Post subject: Reply with quote
I just purchased a spec stage 2+ according to the manufacturers they told me it will meet my hp and torque requirements 200 to 230 hp on a 924 was $445 including pilot and throwout bearing and alignment tool it's in the post atm
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
