Volvo Front Calipers...correct ones?
simsport
PostPosted: Wed Jul 14, 2010 8:50 am    Post subject: Volvo Front Calipers...correct ones? Reply with quote
I have a set of vOLVO 240 Front calipers but am not sure I have the correct 4 pots.
The gap running through the caliper (the recess for the disc) is 25mm wide....is this the correct set of 4 pots for the 931?
Also, there is a small single bleed nipple on one end of one half of the caliper, as well as the larger nipples at the centre of each half....is this also a bleed nipple?
The size is important because you really dont want to find that you run out if piston travel when the pads wear down, no more piston travel means no brakes!
Thanks
Simon
Blown is always best!
Tas931
PostPosted: Wed Jul 14, 2010 3:16 pm    Post subject: Reply with quote
Post up some pics i should be able to tell you from that.
I will try and remember to measure mine tonight for you.
http://www.fcpgroton.com/product-exec/product_id/10455/nm/Volvo+240+Front+Left+Rebuilt+Unloaded+Brake+Caliper+%281988-1991%29
Cheap as...
Tas931
PostPosted: Fri Aug 27, 2010 3:24 pm    Post subject: Reply with quote
Finally got mine fitted and bled last night looks great.
