Is a 924 turbo a interference motor?
poorsha924
PostPosted: Fri Aug 27, 2010 8:38 pm    Post subject: Is a 924 turbo a interference motor? Reply with quote
Hi
I have a chance to pick up a 1980 924 turbo cheap. It has a broken timing belt. I know the 924 N/A is not a interference engine is the same true for the 924 turbo?
thanks
Steve ")
79 924S snailshell
audi big bore t-body
16" turbo wheels
PostPosted: Fri Aug 27, 2010 9:07 pm    Post subject: Reply with quote
931 is an interFEAReance engine
gegge
PostPosted: Sat Aug 28, 2010 1:13 am    Post subject: Reply with quote
Not with VW flat-tops and 142,5mm rods and I even got a high-lift cam
NO FEAR!
Carl Fredrik Torkildsen
PostPosted: Sat Aug 28, 2010 3:08 am    Post subject: Reply with quote
Yep. Bent valves = headgasket, valves, etc.
Pick up some larger valves and make a little more power
PostPosted: Sat Aug 28, 2010 4:14 am    Post subject: Reply with quote
NO FEAR!
are the VW flattops expensive? i'm begining a rebuild on my other motor and i'm wondering what pistons to use.
gegge
PostPosted: Sat Aug 28, 2010 6:40 am    Post subject: Reply with quote
morghen wrote:
NO FEAR!
Forged Mahles are rediculus cheap! Not optimal in therms of combustion efficiency, but got some advantages like super strong and non interference.
Best performance with dished non-interference pistons? Ask ideola!
flosho
PostPosted: Sat Aug 28, 2010 7:12 am    Post subject: Reply with quote
I didn't know all it takes is VW flat tops (can we get these coated and beefed up too?) plus 142.5mm rods and we are interference free!!!
[This Space For Rent]
PostPosted: Sat Aug 28, 2010 7:47 am    Post subject: Reply with quote
924 turbo, high performance engine...no interference....sounds perfect !
where can we get quotes for those pistons?
flosho
PostPosted: Sat Aug 28, 2010 9:06 am    Post subject: Reply with quote
Does Dan sell em?
PostPosted: Sat Aug 28, 2010 9:20 am    Post subject: Reply with quote
flosho wrote:
VW flat tops plus 142.5mm rods and we are interference free!!!
It could be my pea brain acting up again, but I'm having a hard time seeing how this is possible while maintaining the same compression.
PostPosted: Sat Aug 28, 2010 9:30 am    Post subject: Reply with quote
rods are shorter?
PostPosted: Sat Aug 28, 2010 9:34 am    Post subject: Reply with quote
Easy. The 931 piston has a dish in it. By using a flat top and toying with the pin height plus rod length, you can make up the volume in the combustion chamber, and lower the top of the piston. The OEM pistons have a dish that is approximately 15-16mm deep, have about a 10mm lip all the way around and have steep sides to the dish. The Diamond versions I've commissioned have about 8mm deep dish, about a 5mm lip all the way around and have shallower sides to the dish.
The OEM piston is designed with 0 piston-to-deck clearance, meaning that the lip portion of the pistons sits flush with the deck at TDC. By eliminating the dish and dropping the piston crown further into the bore, you still have volume in the piston, but you also end up with some clearance from the piston crown to the deck. Voilą. Non-interference.
PostPosted: Sat Aug 28, 2010 9:39 am    Post subject: Reply with quote
Yep, over my head.
So, you've spun one of your Diamond motors with a cam installed and verified clearance?
PostPosted: Sat Aug 28, 2010 9:56 am    Post subject: Reply with quote
Wouldn't that make more of the cylinder bore part of the combustion chamber?
Wonder if that would cause any problems long term?
PostPosted: Sat Aug 28, 2010 11:10 am    Post subject: Reply with quote
Rasta Monsta wrote:
Yep, over my head.
Yes.
