blurred_line
Joined: 23 Jun 2010 Posts: 40 Location: Vortex of Hell (Illinois)
Posted: Fri Aug 06, 2010 4:18 am Post subject: Oil Pump? |
I'm currently rebuilding the motor in my 81 931, my question is should I replace or rebuild my oil pump? I noticed that a new one is over $600! What have you guys done? _________________ 1981 924 Turbo |
Posted: Fri Aug 06, 2010 5:09 am Post subject: Re: Oil Pump? |
| blurred_line wrote: | | I'm currently rebuilding the motor in my 81 931, my question is should I replace or rebuild my oil pump? I noticed that a new one is over $600! What have you guys done? |
New oil pumps are NLA. Don't worry about it, the pump itself rarely fails, it's the pressure relief spring that's the problem. Leave it alone and worry about if it doesn't produce enough oil pressure once you get the motor going. The spring can be fiddled with or replaced easily with the motor in situ. _________________ erstwhile owner of just about every 924 variant ever made |
blurred_line
Posted: Fri Aug 06, 2010 6:04 am Post subject: |
Thanks ideola! I'll also be ordering some stuff from you throughout the project. _________________ 1981 924 Turbo |
Posted: Fri Aug 06, 2010 6:30 am Post subject: |
Cool, let me know how I can help. And FWIW, if your pump ever does fail, I have several spares that I've been stock-piling... _________________ erstwhile owner of just about every 924 variant ever made |
v8carreragts
Posted: Sat Aug 07, 2010 10:53 am Post subject: |
I had an oil pump failure once. A really odd one. My ex-wife came home from work one day in her 82. She pulled into the driveway and shut it off. A little while latter it wouldn't start. I thought it was something with the starter because the solenoid clicked but it didn't spin the engine. So I got in and rolled it backwards (we had a long sloping driveway) and let the clutch pedal up and it skidded to a stop. The engine was locked.
I pulled the engine expecting the worst. I took off the oil pan and everything was perfect. Nothing broken. The head and cam looked the same. I was stumped until I took off the oil pump. What happened was a piece of TIG wire got logged between the outer oil pump gear and the casting. This is what locked the engine. I brought it to work and we froze the gear with nitrogen and heated the casting and we couldn't get it out. Then we just cut the casting. The piece of TIG wire was fused to the gear and it cut into the casting.
I looked at the pick up and the screen was in perfect condition but it looked like a piece of TIG wire had broken off from inside of the pick up from the weld between the tube and the large end. All I can figure was that it took 82000 miles to break off and it happened just as she turned off the engine. |
peterld
Joined: 10 Dec 2006 Posts: 987 Location: Noosa Heads QLD Australia
Posted: Mon Aug 09, 2010 12:07 am Post subject: |
The oil pump is the least of your worries...like much of the basic bottom end structure of the 924 it is over-engineered and very sturdy. certainly you should disassemble it , check it and clean it, but I doubt very much you will find any significant wear.
One of mine has done over 200k and was on the motor when shrapnel from a piston spread itself throughout and yet is most serviceable. As Dan mentioned - relief springs can go 'soft' but usually that's it. _________________ 80/81 932/8 ROW |
blurred_line
Posted: Mon Aug 09, 2010 12:01 pm Post subject: |
Can you get a "rebuild kit" or a spring replacement? If I'm pulling the engine out and doing a rebuld/ clean the if I can replace it now rather then later that would be perfect. _________________ 1981 924 Turbo |
Posted: Mon Aug 09, 2010 12:25 pm Post subject: |
Don't worry, it's very easily replaced even with the motor in the car. If it's not broke, don't fix it. _________________ White 87 924S "Ghost"
