Got Webers? What accelerator cable are you using?
PostPosted: Wed Aug 18, 2010 11:26 am    Post subject: Got Webers? What accelerator cable are you using? Reply with quote
If you have Webers you already know the stock accelerator cable will not work -- too short. So I was hoping someone could give me a source, manufacturer and most importantly a part number for the cable they're using.
I've heard Lokar but don't know what part # to order...
TIA
the_mad_electrician
PostPosted: Wed Aug 18, 2010 11:58 am    Post subject: Reply with quote
I'm using the stock cable and the stock mount. its just somethign for temp but it works.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
PostPosted: Thu Aug 19, 2010 12:33 am    Post subject: Reply with quote
I've been looking into this for throttle and shifter cables for my DSR... here's some resources:
http://www.flanderscables.com/FlanCableSearch.html
They sell DIY parts you can assemble your own.
These guys don't have much on their website, but I just got their catalog yesterday, and I'm sure they can make anything you need!
http://www.push-pull.com/
PostPosted: Thu Aug 19, 2010 2:16 am    Post subject: Reply with quote
Thanks guys. I appreciate the suggestions. Keep em coming.
I wish I knew what I was looking for. Then I could probably spec what I need at one of those build-your-own sites. But I was hoping someone could give me a lokar part # or something and I could just order it. I'd have to pay my guy $85/hour to spec $10 worth of cable and fittings, and that's not good economic sense at this point if you know what I mean...
PostPosted: Thu Aug 19, 2010 3:15 am    Post subject: Reply with quote
I'll look at the Lokar cable I have and see if I can remember the part number. I've not gotten it completely installed yet, but it looks to be more than long enough to work with the linkage on my throttle bodies.
PostPosted: Thu Aug 19, 2010 4:45 am    Post subject: Reply with quote
Yeah, if you could get a part # and post it, that would be SUPER!
DOCO
PostPosted: Tue Aug 24, 2010 12:40 am    Post subject: Reply with quote
hey emoore does your throtle lever pull straight down.im going to be useing a fulcrum to make mine work just making it now.pretty simple outfit.kinda of a bellcrank.it has 2 arms in the shape of a v,well a little wider than a v .the lower arm is longer than the upper arm.it will mont on the intake that bolts to the head.then i will be able to use the stock cable,it will pull the upper arm ,inturn the lower arm mounted in the pivot will pull straight down and full open my carbs.been messing with this all summer.makeing and remaking.im dam close now.still some adjustments.then it will go to be made of billet aluminum.that will cost!!!
Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR"
PostPosted: Tue Aug 24, 2010 2:41 am    Post subject: Reply with quote
Take a look over at the "before and after" thread. I have a solution but I'm not sure if its what I'll be using over the long term.
Still hoping for pics and part #s if anyone has them...
PostPosted: Tue Aug 24, 2010 2:48 am    Post subject: Reply with quote
I would be looking at the Diy site posted dude, paragon has a really full catalog too.
PostPosted: Fri Aug 27, 2010 2:34 am    Post subject: Reply with quote
Jegs sells 'em too - www.Jegs.com.
