Lurching issue
mr_hyd3
PostPosted: Wed Jul 28, 2010 2:36 pm    Post subject: Lurching issue Reply with quote
So I'm looking at buying a 924 but I'm worried about the lurching problem it has. It starts up fine but when it's going down the road apparently it starts to lurch after a minute or two. I think it may be a gear problem but I'm not sure.
Any ideas would be extremely helpful
Scorpio
PostPosted: Wed Jul 28, 2010 11:58 pm    Post subject: Reply with quote
sounds like an Adams Family car
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
PostPosted: Thu Jul 29, 2010 3:32 am    Post subject: Reply with quote
Could be fuel delivery or ignition related.
Can you tell us what year 924 you're looking at?
How old is the gas in the tank?
When was the fuel filter last changed?
How are the fuel lines under the car?
Any idea on the age of the fuel pump?
What condition does the wiring under the hood look like?
How about the fuse panel and under-dash wiring?
brealytrent
PostPosted: Thu Jul 29, 2010 3:55 am    Post subject: Reply with quote
My car does the same thing. After a year of daily driving, still alive.
I've tried multiple things, changing the timing, changing the plug wires, checking the egr valve, nothing. It has to be an electrical problem, but where?
1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman
View user's profile Send private message Yahoo Messenger MSN Messenger
mr_hyd3
PostPosted: Thu Jul 29, 2010 5:11 am    Post subject: Reply with quote
its an 89, fuel filter replaced not too long ago, fuel pump has been looked at and there are no apparent issues, all parts original except for new fuel filter and new injectors not too long ago. As well as a new exhaust system if that makes any difference
mr_hyd3
PostPosted: Thu Jul 29, 2010 5:36 am    Post subject: Reply with quote
and i have images now of the things you asked about but i dont know how to post them in the thread[/img]
Go big or go home
joejax
PostPosted: Thu Jul 29, 2010 8:00 am    Post subject: Reply with quote
Wow! An '89? Talk about rare.
Definitely sounds fuel related.
I got nothin'
Uhhh...you got any pics?
Zeek
PostPosted: Thu Jul 29, 2010 10:43 am    Post subject: Reply with quote
Do you have an issue with sudden spasms of your right leg?
No? Never mind, then.
D Hook
PostPosted: Thu Jul 29, 2010 10:48 am    Post subject: Reply with quote
They didn't make an 89. How 'bout a '79?
'80 924 n/a SOLD
mr_hyd3
PostPosted: Thu Jul 29, 2010 1:30 pm    Post subject: Reply with quote
yeah sorry 78 mistype on the date. So what should be the first things i look for as to whats causing the problem? I've looked up all the troubleshooting info i can but nothing pertains to a lurching issue after you get it on the road
Go big or go home
!tom
PostPosted: Fri Jul 30, 2010 2:37 am    Post subject: Reply with quote
Fuel pump relay and associated wiring.
Ignition switch.
78 924 NA
5-lug
PostPosted: Fri Jul 30, 2010 3:19 am    Post subject: Reply with quote
Lean running. Check system and control pressures, and check WUR function. If pressures are good, adjust mixture.
mr_hyd3
PostPosted: Fri Jul 30, 2010 4:33 am    Post subject: Reply with quote
Ok so what would be the best way to go about testing those pressures?
Go big or go home
PostPosted: Fri Jul 30, 2010 4:45 am    Post subject: Reply with quote
There's some dude on the Board who sells the appropriate pressure test kit for CIS, but his name is slipping my mind ATM. . .
Maybe he'll reply to your inquiry.
mr_hyd3
PostPosted: Fri Jul 30, 2010 5:04 am    Post subject: Reply with quote
how much would it cost for said kit? If there's an easier way to go about testing for the problem i would rather do that seeing as this is a first car and i would prefer to not put all of every paycheck into it
Go big or go home
