Wet Floorboard
redporsche
PostPosted: Tue Feb 19, 2013 11:58 pm    Post subject: Wet Floorboard Reply with quote
I discovered over the weekend that the carpet was wet behind my passengers seat. I thought maybe it was the drain hose from the sunroof but that exits in the rear wheelwell. Any ideas. Maybe someone has seen this before. Also is the Fan assembly for the interior removeable from under the hood?
I love gereatric rock.
xanderdeg
PostPosted: Wed Feb 20, 2013 5:38 pm    Post subject: Reply with quote
Here's the answer to your question about the heater!
http://924board.org/viewtopic.php?t=18042&start=0&postdays=0&postorder=asc&highlight=944+spoiler+install&sid=8c2c8a414817db343ff4f2503ab5b59e
Hope it helps!
redporsche
PostPosted: Wed Feb 20, 2013 10:52 pm    Post subject: Reply with quote
Thanks, I'll give it a try.
scriblz7
PostPosted: Fri Feb 22, 2013 9:05 am    Post subject: Reply with quote
wet floorboards are probably from a leaky sunroof. I just replaced the seals on mine and that has fixed the same problem.
Riley
79 924 n/a with gt body
15 VW GTI
