CorsePerVita
Posted: Thu Aug 12, 2010 8:22 am Post subject: fuel pump still not working on 914 |
I got everything else working, EVERYTHING!
Got my brakes working, all systems such as lights, ignition, all working now on my little 914. Only the fuel pump isn't turning on which is confusing the hell out of me.
SO CLOSE.
I'm a tad confused since the actual pump turns on if I user my jumper cable to hit pin 13 for the pump and it turns right on.
When I checked my relay board pin 13 on the board gets 12v. but when i actually turn the car on the fuel pump does not turn on or prime, it's very odd. 12v is 12v so what gives... ???
Someone said "Oh i think it's switched by the ground on the ecu" but this makes no sense to me. The fuel runs a ground to the firewall directly from the pump. The positive cable goes onto pin 13 for the relay board. So when 12v is applied to it, it turns on. Pin 13 gets 12v on the board, but when it's hooked up it does nothing.
Seriously just wtf.... Perhaps it's badly soldered and not enough amperage? _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
Posted: Thu Aug 12, 2010 9:07 am Post subject: |
I would guess that the solder joint on the board is bad and is not passing enough current. _________________ Stefan
CorsePerVita
Posted: Thu Aug 12, 2010 9:18 am Post subject: |
I was testing the wrong wire. Sorry, found out it is NOT getting 12v.
However, wire 14 is the power for this relay. The circuit itself gets 12v all the way down through the fuse which is great.
Aside from there it's anyone's guess. I tried also double checking relays and swapping them since they're all the same, no luck. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
CorsePerVita
Posted: Thu Aug 12, 2010 10:12 am Post subject: |
I did not try that. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
Posted: Thu Aug 12, 2010 10:27 am Post subject: |
If the "percussion adjustment" works then doublecheck the connections and wiring to ensure they are getting all the current they should be and if that checks out, then replace the relays.
If you feel adventurous, you can try to open the relays and clean the contacts, but that's likely to end up with new relays and a bunch of random parts on your bench.
Still, kinda fun tinkering and learning how stuff works! _________________ Stefan
CorsePerVita
Posted: Thu Aug 12, 2010 10:35 am Post subject: |
Thanks Stefan, I will give that a try  _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
CorsePerVita
Posted: Thu Aug 12, 2010 12:35 pm Post subject: |
Good to go! Fuel is working!
Buuuuuuuuuuuuut now i've got no spark. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
craigddavis83
Joined: 20 Feb 2006 Posts: 29 Location: winchester,va us
Posted: Mon Aug 16, 2010 1:23 am Post subject: |
Relay? Yes. No spark? oh problems that never stop. There is a 914 up the road from me I wish I could buy so I could own 2 Porsches. Anyway check your distributor and rotor contacts for corrosion if the car has been sitting wires for rodent damage or bad coil possibly. I don't know how the 914 is but its probably a very similar ign. system. _________________ 1977 924 2.0L N/A "The Track Car" (soon!)
1995 Integra 1.8L "The Wife's Sleeper"
1968 Harley XLCH "The Family Heirloom"
2005 Honda CRF50 "The Pit Bike of Doom" |
