VW : Struts/Shocks Help
owenexile
PostPosted: Mon Jun 14, 2010 6:58 pm    Post subject: VW : Struts/Shocks Help Reply with quote
I got my car yellow stickerd and had to take it over the pits again. The guy failed me for having about 1cm of play in my struts when the car is jacked up. A mechanic friend of mine told me all the VW Struts got that play in it , is this True or do i need to replace my struts? Im scared if i do replace it and i still got that play in it the guy would have wasted $300 of my money!!
Thanks
924 1982 N/A
For some reason theres always a earth problem somewhere with this car...
PostPosted: Mon Jun 14, 2010 11:56 pm    Post subject: Reply with quote
Play in what direction?
owenexile
PostPosted: Tue Jun 15, 2010 12:18 am    Post subject: Reply with quote
Just up and down , But im just gno replace the "Bushings" Then put some of new "watery grease" in there and take it back and tell the inspecter guy i did replace it.
But im still Wondering about the play?
924 1982 N/A
PostPosted: Tue Jun 15, 2010 6:19 pm    Post subject: Reply with quote
Is it a VW, or a Porsche?
VWs do have some play when you jack the car up, because they don't have strut mounts that are bolted to the inner fenders like the 924/931/924S/944/951 family does.
joecitizennn
PostPosted: Tue Jun 15, 2010 10:32 pm    Post subject: Reply with quote
They ream yourass in the name of safety. Typical government.
PostPosted: Wed Jun 16, 2010 1:20 am    Post subject: Reply with quote
Ha that basterd safety dude.
owenexile
PostPosted: Wed Jun 16, 2010 2:19 am    Post subject: Reply with quote
Im sorry Mate , English isnt my 1st Language , but do u mean that i should have the play in my strut? On the Strut theres a VW stamp on it , so im confused?
924 1982 N/A
PostPosted: Wed Jun 16, 2010 4:22 am    Post subject: Reply with quote
Are you asking about front struts that are installed in a 924, OR front struts that are installed in a VW (like a Jetta or Golf)?
owenexile
PostPosted: Wed Jun 16, 2010 5:03 pm    Post subject: Reply with quote
Im asking about the front struts on the 924 , but since it got that VW stamp on , im confused
924 1982 N/A
owenexile
PostPosted: Wed Jun 23, 2010 3:58 pm    Post subject: Reply with quote
Ok , im going to just "re-oil" my struts , which type of oil do i get and how much do i use per strut?
Thanks
924 1982 N/A
9XX Girl!
PostPosted: Wed Jun 23, 2010 5:51 pm    Post subject: Reply with quote
Motorcycle Fork Oil (Med/Heavy 15W) 250ml per side
(new oil is a good investment as the stock shocks are made by Koni, much better quality than some after-market insert for £100 per side)
But if you have play, be sure to clean the valves in the shock while you have it apart.
How-to / Stock Shock Absorber Refurbishment
owenexile
PostPosted: Sat Jun 26, 2010 9:16 pm    Post subject: Reply with quote
Ok , Got the oil , Got my O-rings (lower one i could not find so i got a round one and when i pushed it in it cut some of the "round-ish" bit off now its also flat and its a nice fit)
When do i put in the oil? Do i poor it in before putting the last part on before screwing it close? ( the part with the top O-ring)
Thanks
924 1982 N/A
9XX Girl!
PostPosted: Sat Jun 26, 2010 10:44 pm    Post subject: Reply with quote
Be carful about cutting seals
I would guess that the play you have been talking about is free movement before and resistance kicks in when extending and compressing the shock. This is more likely to be the bottom or plunger valve not closing quick enough due to crap. The bottom one is more prone to this as this is where the sediment sits from aged oil. Take them apart and clean them in coca-cola. The plunger seal sits baggy anyway, (a bit like a piston ring) but will seal once in. Its a bit fiddly to get back in the tube as you have to compress it with your fingers.
The "o-ring" on the top cap will be fine if you have had to trim it a little.
Put the end valve on the bottom of the tube, put the plunger in the tube, place the assembly in the strut leg, push the plunger down so the shock is compressed, pour in the oil, (it doesn't matter if you get some in the outer as well as the inner of the tube) then push the top assembly with oil seal into the top of the strut. This is a bit fiddly as the top cap centralizes the inner tube. Then screw the retaining cap down.
You then need to extend and compress the shock a couple of times to prime it.
owenexile
PostPosted: Tue Jul 06, 2010 12:30 am    Post subject: Reply with quote
Hey
9xxGirl , can u mayb tell me how that valve(the one which doenst need the bolt removed to get out) comes together again?
Ive put evrything back again , and now my strut goes down easy and comes out really hard. If im correct the strut needs to go in and out equally hard?
Thanks
924 1982 N/A
9XX Girl!
PostPosted: Tue Jul 06, 2010 3:17 am    Post subject: Reply with quote
owenexile wrote:
Hey
Thanks
Ok if it goes down easy but comes up with resistance its the bottom valve not closing correctly.
Correct me if i am wrong? You want to know the order of assembly for these parts.
Don't tell me you have taken BOTH apart without noting the order.
You are lucky, i have one that is not in a strut. I will take it apart and post pics, but it may take a couple of days as i'm up to my eyeballs
