B
Posted: Tue Jul 13, 2010 12:53 pm Post subject: adhesive question |
Hey everyone
I wanted to know if anyone knows what type of adhesive was used where the fender is screwed onto the body along the top edge ? - it is gray in color and did not seem like the same seam sealer used elsewhere -(epoxy maybe?)
I am in the process of repairing some rust and wanted to clean things up before coating it up with a rust sealer from Eastwood
funny how you start to work on a suspension and end up repairing the entire front end - fenders and all
any help would be greatly appreciated
thanks
Sean _________________ 1979 924 n/a
BAE turbo
5-speed snailshell |
BigJohn
Joined: 11 Jul 2010 Posts: 7 Location: Southampton UK 1983 924 5 speed
Posted: Tue Jul 13, 2010 4:51 pm Post subject: |
Funny you should mention starting work on the mechanicals and wandering off to do body and rust prevention, whilst poking round under mine yesterday I was shocked on how much "Loose" under-seal and rust there was on a car supposedly Galvanised? I ended up covered in dust and lumps of underseal, so it was out with the Waxoyl gun and liberal coats of waxoyl sprayed everywhere, but for some reason the mask I was wearing leaked and I ended with a waxed nose, not pleasant. Then noticed the time, rushed inside to get my clothes into the washer before the Wife arrived from work, didn't work as she was suspicious why all of a sudden I was using the washer oops.
Back to your "Epoxy" I should imagine that is exactly what it is. And I wish you well, horrible sticky stuff. _________________ A Furry Creature Told Me I Was Simples |
Scorpio
Posted: Tue Jul 13, 2010 7:01 pm Post subject: |
not sure just fitted my front fenders..may just leve it out not sure...other option includes seam sealer or rubberized underbody, carefully painted on..black same colour as the engine bay _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!! |
B
Posted: Tue Jul 13, 2010 9:05 pm Post subject: |
thanks
yeah I knew there was probably some corrosion that I would deal with come winter, but I saw what looked like a bulge in the lower fender and tapped it with a rubber mallet - - when I heard that crunchy cereal sound I knew I was in a little trouble.
I too have been covered in that white goop that they covered the inner wheel well area with only to be continually disappointed with numerous starts of rust.
So far I am planning to patch any holes, coat with rust encapsulator and chassis black from Eastwood. I have already sprayed inside inner fender with a inner fame coating that is supposed to seal and protect - hopefully that helps as well.
thanks
BAE turbo
Scorpio
Posted: Tue Jul 13, 2010 9:24 pm Post subject: |
ive used POR15 so far still perfect...but thats a year in the garage not in the elements..then again my beast will spend most days in the garage except when it comes out to play  _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
Posted: Tue Jul 13, 2010 10:44 pm Post subject: |
On the fender - I'm sure that's seam sealer, and not an epoxy that's used between the fender and body (upper engine compartment seam). It's available in different forms, but caulk gun style is best for re-doing that seam. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Wed Jul 14, 2010 3:46 am Post subject: |
You know what Im usin there instead of the epoxy or seam sealer..
is vulkham 116 polyurathane sealant its grey and course ...good stuff
lasts forever. You can get it in smaller tubes at hardwares stores. _________________ 1979 porsche 924 Na
B
thanks - that is what I initially thought as well - it just looked much different - I did get some of the sealer in the tube like that -
thanks
BAE turbo
