RC
9XX Girl!
Joined: 20 Sep 2009 Posts: 1617 Location: Cornish Riviera SW England
Posted: Wed Jun 09, 2010 9:03 am Post subject: |
Look.......
http://cgi.ebay.com/ebaymotors/porsche-924-early-screw-VDO-fuel-level-sender-_W0QQcmdZViewItemQQhashZitem255b1fa8e1QQitemZ160442591457QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
is this the puppy?
I will try to measure my later one off my 1984 if it isn't raining, tomorrow for you.
Just out of interest RC and completely OT (as you are one of the few people on this board that would know what I'm on about). ....My radio relay chatters.
The radio relay is energized when the key is pushed into the ignition barrel, (pushed in, not turned, just pushed). It runs the sunroof as well as the radio. I think the ignition switch is a bit dickey. Not sure until i investigate.
It is mostly on when the key is in the ignition but the switch seems to break then re-make when i go over bumps. The rest of the ignition switch functions fine so..... i was thinking of dumping a reasonable size electrolytic capacitor over the coil of the radio relay. Maybe put a diode like a IN1004 in series with the live feed to the coil (and cap) to stop any other loads (other than the radio relay coil) in the same circuit from discharging the cap. I'm hoping this will hack the intermittent ignition switch problem and keep the radio relay coil energized when the power to it is momentary lost due to vibration. So what size cap do you think would do the job, 10,000uf 16v? _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
BOTH ON THE ROAD, BOTH USED EVERY-OTHER DAY |
porsche.racer
Joined: 20 Jun 2006 Posts: 106 Location: california, US
Posted: Thu Jun 10, 2010 7:17 am Post subject: FOR SALE NOW on ebay |
not over priced!!!!!
porsche 924 early screw in VDO fuel level sender (160442591457) _________________ 1987 911 3.6L Carrera with LSD
1986 944 Turbo (Track)
1972 911 3.0L Turbo Look
1988 944
100's of good used parts MUST GO
Check me out on EBAY I.D. porsche.racer |
9XX Girl!
Posted: Thu Jun 10, 2010 3:38 pm Post subject: Re: FOR SALE NOW on ebay |
| porsche.racer wrote: | | not over priced!!!!! |
Exactly!
porsche.racer? You haven't got any 944, 2" (52mm) gauges have you?
I need a clock and a voltmeter in Black/Yellow _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
porsche.racer
Posted: Thu Jun 10, 2010 4:22 pm Post subject: Re: FOR SALE NOW on ebay |
| 9XX Girl! wrote: | | porsche.racer wrote: | | not over priced!!!!! |
Exactly!
I need a clock and a voltmeter in Black/Yellow |
I will have to check, I have a collection of clocks..... but they have not been tested for some years... I will check... no go on the voltmeter.
MIke _________________ 1987 911 3.6L Carrera with LSD
1988 944
RC
Posted: Sat Jun 12, 2010 4:20 am Post subject: Re: Fuel Gauge Sender |
| RC wrote: | I am looking into the feasibility of fitting the common fuel sender, #477 919 051 B, the 5 screw down type to an earlier 77 tank.
Could anyone please tell me the overall outer diameter at the flange and the minor diameter at the tube. The PCD of the 5 mounting holes |
Anyone?
Anyone with one screwed in able to measure the internal and overall measurements of 2 adjacent screw heads? (average pitch) |
RC
Posted: Sat Jun 12, 2010 12:42 pm Post subject: |
Sorry, should have said PCD = Pitch Circle Diameter. It's the diameter of the circle that the 5 screws are on. Like our wheels have a PCD of 130mm.
It`s a bit difficult to measure on 5 holes but easiest to calculate from the distance between 2 adjacent hole centres. There`s a reinforcing plate fixed to the inside of the tank underneath where the sender should screw but its not very wide and feels like ridges on it. I Really want to see where the holes will go before I start drilling & tapping them or ordering the part. Would like to see basic info like this posted so others can access it if ever needed. |
Harm
Posted: Sun Jun 13, 2010 6:32 am Post subject: Re: Fuel Gauge Sender |
PM send.
Regards, Harm. |
9XX Girl!
Posted: Sun Jun 13, 2010 8:12 am Post subject: |
I know exactly what you mean RC.
I was hoping to get the diameter measurement to you but I was called into work yesterday and have to work again tomorrow also. Plus i ended up getting drunk this eve while watching England play USA in the World Cup.
Will see if i have time on Monday if someone hasn't posted the dimensions you need by then.
I cleaned my fuel sender 2 years ago and i guess it needs looking at again. I have just brimmed the tank (which i don't do too often) and my gauge is only reading 3/4 of a tank full.
Would it not be easier to bid for porsche.racer's screw-in one?
@porsche.racer, any luck with the clock? _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
RC
Posted: Thu Jul 01, 2010 1:46 am Post subject: |
A big thank you to Harm for the measurements and to Mike (porsche.racer) for the OE sender. Although not fitted or tested yet it does "look" good. Hopefully will save drilling & tapping for a while.
Upon reflection, the single O ring seal, as fitted to early models, never leaked anyway. Replacement O rings are cheap at the local seal shop.
The later type has 6 potential leak sources, the rubber gasket and each of 5 screw holes that need a (nylon) washer to seal them.
Wonder why Porsche changed design? |
