hitbyastick
Joined: 25 Jun 2009 Posts: 51 Location: Livermore, CA
Posted: Wed Jun 02, 2010 5:17 am Post subject: Should the turbo spool in neutral? |
If I bring up the revs in neutral I can hear the turbo spool up all the way to 7 psi. Is that normal? _________________ 1982 Porsche 924 Turbo |
Posted: Wed Jun 02, 2010 5:27 am Post subject: |
Mine doesn't, has to be under a load. Your car might be burning too rich. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Wed Jun 02, 2010 5:52 am Post subject: |
Are you sure it's spooling up to 7 PSI? Or are you just hearing the turbo whine? At what RPM? _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Jun 02, 2010 6:02 am Post subject: |
I can get mine spinning at 5+ with a little rythmic revving. _________________ Toofah King Bad
Posted: Wed Jun 02, 2010 6:18 am Post subject: |
in neutral i cant hear it...while in gear it sings beautifully. _________________ Supercharger and EFI kits
Rich H
Posted: Wed Jun 02, 2010 6:31 am Post subject: |
If you go from idle to flat out it might briefly spool but it needs load to sustain boost. _________________ 1994 Lotus Esprit S4 - Work in progress...
flosho
Posted: Wed Jun 02, 2010 6:42 am Post subject: |
My turbo doesn't produce any boost in neutral, although you can still hear it whistle.
I'm fairly certain that most turbos shouldn't produce boost without a load unless something is a miss in the engine parameters, or with the help of spark cut.  _________________ [This Space For Rent] |
931Owner
Joined: 14 Feb 2009 Posts: 352 Location: Chicago NW Suburbs
Posted: Mon Jun 07, 2010 2:14 pm Post subject: |
Not sure about neutral... but it's a very concerning moment when it spools up in reverse! I did that on my Audi 200T when wanting to back up about 50-70 meters on a I pier! Let me tell you it's not fun under boost esp with water on both sides of you.  _________________ 1980 Turbo
-too many cars and too many motobikes |
