TurnKey
Joined: 13 Feb 2010 Posts: 5 Location: Eureka, California
Posted: Tue May 04, 2010 7:22 am Post subject: Ran Great 2 days ago... |
I just purchased a 1980 931 from my In-Laws. The car has been in the family for about 15 years or so. It was driven from their house to mine, about 1100 miles. It ran perfectly all the way home. I have driven it around town since without a problem. On Saturday I washed it at the local do-it-yourself carwash. It ran horrible on the way home because of the water that got under the hood. I waited a few hours to let it dry and it ran perfectly again.
Yesterday, I started it and drove to the gas station. After going inside for a minute and coming back out, the car would not start. It has an old "the ungo box" in it but i was told that it is not hooked up and has not been touched in years. After tinkering with the car for a few minutes it started up and ran great again.
Today, I went out and tried starting the car and it will not start. The starter cranks great but the car will not attempt to start. I messed with the "ungo box" again and still nothing. I checked the coil for spark and at the #1 plug wire. Good spark in both places.
Any Ideas what could have caused this problem all of a sudden?
Thank You _________________ The Porsche Noob
'80 931 |
Posted: Tue May 04, 2010 7:24 am Post subject: |
You've verified spark and air.
Do you have fuel? _________________ Stefan
TurnKey
Posted: Tue May 04, 2010 8:26 am Post subject: |
I'm guessing not. What is the easiest way to check? I'm pretty new to all of this. _________________ The Porsche Noob
'80 931 |
Posted: Tue May 04, 2010 8:44 am Post subject: |
Go click on the 924 Technical Section and the FAQ at the top of the page.
Then look around for a link to the Bosch CIS troubleshooting book.
There is also the 931 Resuscitation thread: http://www.924board.org/viewtopic.php?t=22724
My guess? You have a bad ground under the dashboard that is causing the fuel pump relay to not trigger or perhaps another connection issue with the fuel pump relay circuit or a failing fuel pump. _________________ Stefan
Posted: Tue May 04, 2010 12:18 pm Post subject: |
An easy way to check that everything else it ok is to get some ether starting fluid, give her a quick shot, and crank. If it starts, you've got a (lack of) fuel problem.
Check pump, fuse, relay, wiring... |
Posted: Tue May 04, 2010 10:34 pm Post subject: |
One quick-easy item to check..
The overboost cutoff switch - check that its' wire is tightly attached.
(Front-center of the upper charge tube, a few inches to the left of the throttle.) _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Tue May 04, 2010 10:49 pm Post subject: |
I had to google 'ungo box', now I'm in the know! Also, did the car sit for a long time? Maybe gas in tank varnished some, dirt back there might have moved to the fuel filter. Change that filter yet? Is it on correctly? Are the three drain tubes cleared of leaves and dirt? Maybe that middle one is plugged and water worked it's way onto the relay/fuse area? Check the cap/rotor for water? _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
TurnKey
Posted: Fri May 07, 2010 2:07 pm Post subject: |
Thanks for everyone's input. I am still working on the fix but have very limited time right now. I will try to remember to let you know what i find to be the cause of this annoyance.
Thank you _________________ The Porsche Noob
'80 931 |
Posted: Fri May 07, 2010 10:31 pm Post subject: |
| Smoothie wrote: | One quick-easy item to check..
(Front-center of the upper charge tube, a few inches to the left of the throttle.) |
Got hit by that one two weeks ago. Bought a new switch as bypassing it and earthing cured the problem. However the new switch had same issue. Bad earth to the charge tube!!! That was an annoying £30 lesson! _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
TurnKey
Posted: Sat May 15, 2010 10:30 am Post subject: |
Turned out to be the Fuel Pump Relay...New relay and it runs great again.. Thanks for the help _________________ The Porsche Noob
'80 931 |
